Dana 35 Durability; locked on 33's - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Dana 35 Durability; locked on 33's
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTime To Save On Yukon Lockers!Rough Country Lift Kits and Parts!
Unread 07-20-2010, 05:23 PM   #31
Deacon
Deacon's Avatar
Well, to be fair the S35 changes out everything but the tubes and housing, basically, so while it still looks like a D35 from the outside, there's nothing really left of the original 35.
Deacon is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 05:59 PM   #32
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Except the ring and pinion...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 06:10 PM   #33
cbrookerd
are aftermarket ring and pinions such as the superior not stronger than the stock? or are they just more expensive for no reason?...I mean, superior, yukon, and some other of the better brands out there talk about using pure 8620 steel in their r and p's....so is that not an upgrade to the oem stuff?
i would assume, that if somebody is looking at upgrading with an s35, they have either already or are going to regear to a better ratio...so if they buy better made ring and pinion gears, isn't that also strengthening the d35?
cbrookerd is offline   Reply With Quote Quick reply to this message
Unread 07-20-2010, 06:17 PM   #34
cbrookerd
somebody already posted a link to it...but check out my thread here to help this conversation along...
http://www.jeepforum.com/forum/f9/au...-d35c-1071483/
Unread 09-12-2010, 12:44 PM   #35
jefro_97tj
im very easy on mine but i have friends that have showed me what a 35 can handle.4.0 3.07's welded spiders 32's and lots of hard wheeling and pavement burnouts.i wouldnt do it to mine but ive seen it done.that set up lasted a summers worth of wheeling and hasnt broke i just sold the guy my old 4.10's.
jefro_97tj is offline   Reply With Quote Quick reply to this message
dana 35 , d35 , lock , locker , locked , durability , strength , 33 , TJ
