Dana 35 to Dana44 Swap - JeepForum.com
post #1 of 18 Old 10-29-2009, 10:55 AM Thread Starter
willydigger
Will a Dana 44 from a 02 TJ bolt in directly with an 05 TJ? Are there any differences with the yoke or drive shaft that need to be considered?
willydigger is offline
post #2 of 18 Old 10-29-2009, 11:06 AM
drummerchukb1
from what ive read, it should be a direct swap. im about to swap a d44 from a 2000 into my 98 once i get it re-geared
drummerchukb1 is offline
post #3 of 18 Old 10-29-2009, 11:13 AM
rideraa
I'm about to do one also, watch your drive shaft length, info I have found says it needs to be a bit shorter (like as little as a 1/4" reported by some, if thats true it could break the "T" case under compression) also was stated a moderate lift would accomodate the difference ... For Rudi 44 you will also need a 1310/1330 u joint and different cables for the parking brake (rear disc)
rideraa is offline
post #4 of 18 Old 10-29-2009, 12:08 PM Thread Starter
willydigger
It's not from a Rubicon. What is considered a moderate lift? I have a 2inch suspension with 1inch BL/MML.
post #5 of 18 Old 10-29-2009, 12:28 PM
Benderff
Benderff's Avatar
Yes it is a direct swap. I'm guessing it has drum brakes, but if it has disk you would need new parking brake cables. The pinion is a little longer, but with your lift you should be fine. Once you get it under your jeep just make sure the driveshaft has enough play that it will not be pushed into you transfercase.
Here is what I just built. It's going under in next week.
Benderff is offline
post #6 of 18 Old 10-29-2009, 12:37 PM
rideraa
your going to have to use your own judgement on the shaft length ... can't help you there ... did you extend your bump stops with the lift ... that maybe some insurance ...
report back .. I'd be interested in your findings .. as of now the soonest i will be installing is Nov 4 ... and that will be with a 4" lift ...
sorry i can't be any more specific ... person above ... says ok....
rideraa is offline
post #7 of 18 Old 10-29-2009, 01:38 PM
bean66
I just did this swap about 6 weeks ago. Yes it is a direct bolt up swap for most of the components.
However if its a RUBI D44 then the snout is a bit longer and it has a 1330 yoke output. You have a few choices here to mount this up,
A. get a 1310/1330 combo u-joint.
B. Have a 1330 yoke welded onto your drive shaft and install a 1330 u-joint. Most drive shops can do this and the yoke only costs another $20 or so.
Some issues i ran into:
1. Disk brake cables vs the stock cables from the drums.
2. Speedo gear change. They are pretty pricey at $80.
3. Vibes, since the snout is longer this increases the shaft angle.
4. Bad bearings in the axle as well as leaking seals.
5. Pump installation and purchase for rubi lockers.
This has led me into, TT, SS SYE and a new DC driveshaft, adjustable control arms.
bean66 is offline
post #8 of 18 Old 10-29-2009, 01:43 PM Thread Starter
willydigger
Are there any vibes or driveline problems with a non-Rubi dana44 due to the longer pinion? How much longer is the pinion?
post #9 of 18 Old 10-29-2009, 01:50 PM
theducksguts
For non rubicon TJ Dana 44's it isn't more than an inch longer. With your lift you should be fine. Just compress the suspension and make sure the slip joint does not contact the Transfer Case. It is not expensive to have a D35 TJ drive shaft cut down and shortened.
Check out my
theducksguts is offline
post #10 of 18 Old 11-15-2009, 10:48 PM
bmxrules39
I want to re-open this thread to say that I was wondering about pinion length because I'm about to do this swap (97 D44 into my 97 D35), I just a super short shaft kit with a TW driveshaft, I have no t-case drop and a 4.5in lift. So I'm thinking I'll be fine to do it, but just wondering..
wHitt
bmxrules39 is offline
post #11 of 18 Old 11-15-2009, 10:54 PM
Benderff
Benderff's Avatar
I did a tummy tuck at the sametime as my axle swap. If I had not done the tuck I would have needed to cut the drive shaft down.
I am on 3.5'' of spring lift and the belly up raised the transfer case output 2 inches. I also have a SYE with a Tom Woods shaft that was cut to size for the lift. I think you will just have to get the axle under the jeep and see.
Here is my write-up vvvvvvvv
Benderff is offline
post #12 of 18 Old 08-30-2010, 06:04 PM Thread Starter
willydigger
Just a quick bump. I installed the Dana44. It took a full 8 hours with several hiccups along the way. Mostly my fault. The biggest problem was a few broken bolts due to an over aggressive impact.
Here are some pics of my drive shaft. This first image is will the Dana35.
Here is the drive shaft after with the Dana44.
Now that I look at it, I think I have a leaking axle seal. Crap!
post #13 of 18 Old 08-30-2010, 06:14 PM
Benderff
Benderff's Avatar
You know you need to have the drive shaft shortened right?
With the seal leak; did you use any sealer around the outside of the axle seal? Did you have the axle shafts pressed apart,and does the new axle have disc brakes??
Benderff is offline
post #14 of 18 Old 08-30-2010, 06:34 PM
wushaw
Rockin jeep
wushaw's Avatar
[QUOTE]You know you need to have the drive shaft shortened right?[QUOTE]
X2
wushaw is offline
post #15 of 18 Old 08-30-2010, 07:31 PM Thread Starter
willydigger
Yeah I know. The pic is for others thinking of doing the swap.
dana44 tracloc swap aloredojr TJ Wrangler Technical Forum 5 11-04-2009 08:22 AM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 12:42 PM
YJ Dana44 swap raZe YJ Wrangler Technical Forum 11 10-28-2006 11:57 AM
TJ rear dana44 and Rubicon dana44 difference jappe TJ Wrangler Technical Forum 10 05-30-2006 01:25 AM
Question-rubicon dana 44 rear-4.10 fit standard tj rear dana44 rytrac TJ Wrangler Technical Forum 3 09-04-2005 02:44 AM
