Dana 35 c-clip eliminator 1st hand experience? - Page 9 - JeepForum.com
post #121 of 126 Old 04-02-2011, 08:29 PM
EricsGreen98Tj
So will the 27 spline C-clip eliminator hold up to 35s and a detroit? Or should I just man up and get the 30 spline eliminator kit and the detroit?
Reason i ask is that I'm gonna do 4.88's and locker(s) f/r but need to upgrade my rear shafts.....I only want to open the D35 up once.....Im on 33's now but when they wear out some 35" MT are goin on. I want to change gears add a rear Detroit and upgrade shafts (C-clip eliminator) all in one weekend and be good to go for quite a few years.
BTW: I already run an Aussie in the front, if that will influence your opinion in any way...
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #122 of 126 Old 04-02-2011, 10:28 PM
joe_jeep
for 35's id go for the super 35 kit, with the c clip eliminator, and the 30 spline locker of your choice. i ran the super 35 kit and 33's, 35's, and 36's with a detroit, and no clip eliminator for years. i think 27 splines is a little small for 35's. jmho
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #123 of 126 Old 04-02-2011, 10:43 PM
RaggedOleMan
I run the 27 spline Superior Evolution series with the C-Clip Eliminator on 33's. I want to step up to 35's, too and have decided it's probably not the best decision, but I believe it's doable. The 488's add a bit to the mix, too, I would think.
My guess is that if you like that spendy pedal, you're probably making a mistake. Besides, if the cost of the Superior Super 35 is in your budget, you're much better off going that route. Over building is under rated...
You know what? I'll bet you, you won't break the 27 spline Superior Evo shafts, but the R&P is another story...if you go with the 27 spline, then I would also go with Superior R&P so they're all in the same family...might get along better. But I'm only guessing...
RaggedOleMan is offline
post #124 of 126 Old 04-02-2011, 11:14 PM
EricsGreen98Tj
Yeah but also remember i run the low output 2.5L too.....and I've already got the Motive 4.88's + install kits for the f/r
post #125 of 126 Old 04-03-2011, 10:13 AM
RaggedOleMan
Well then, you're a daisy if ya do...
post #126 of 126 Old 04-03-2011, 02:17 PM
EricsGreen98Tj
"You aint no daisy....you aint not daisy at tall...." LOL
Dana 44 VS. C Clip Eliminator? 2003X TJ Wrangler Technical Forum 84 10-20-2011 10:03 AM
Superior Dana 35 C-Clip Eliminator Kit Dravintoad TJ Wrangler Technical Forum 60 06-18-2010 07:28 PM
Superior Dana 35 C-Clip Eliminator Kit zbob TJ Wrangler Technical Forum 1 01-25-2010 05:22 PM
Last minute questions on Dana 35 C Clip Eliminator before purchase. ssl90 TJ Wrangler Technical Forum 2 11-09-2009 07:42 PM
Superior Dana 35 C-Clip Eliminator Kit LEONEN TJ Wrangler Technical Forum 109 02-19-2009 05:07 PM
