Dana 35/30 Ring & Pinion Swap - JeepForum.com
post #1 of 9 Old 04-11-2005, 10:21 PM Thread Starter
jzuccarell
I have a 3.07 Dana 35/30 and want to swap to 4.11 for 32" tires. I have heard that I may need to change the carrier too. Can anyone help???
jzuccarell is offline
post #2 of 9 Old 04-11-2005, 10:39 PM
UCTJ
UCTJ's Avatar
yup your going to have to change your carriers.
UCTJ is offline
post #3 of 9 Old 04-11-2005, 11:02 PM
MR.CLIFFORD
MR.CLIFFORD's Avatar
find a 4 banger that upgraded his axles. Should be easy to track down a 4.1x geared D30/35 combo for less than 600 bucks. Then you have all kinds of spares
Custom signature
MR.CLIFFORD is offline
post #4 of 9 Old 04-11-2005, 11:23 PM
hdstn
but you DON"T to swap to 3.73's correct?
'02 TJ 4.0L 5sp
1"BL,REBB, 32" Mud Rovers on AR 23's
hdstn is offline
post #5 of 9 Old 04-12-2005, 08:15 AM
Chile99
Chile99's Avatar
Yep for 3.73's also. That is where the break is. 3.73's up use the same carrier.
99TJ 4.0 Auto, Lifted and Locked with a lot of Junk
94 yj 4.6 Stroker, 14Bolt, HP44, 101 wheelbase
I brake for Junk Yards
Chile99 is offline
post #6 of 9 Old 04-12-2005, 10:19 AM
freedumb
I just recieved my new gears from Randy's R&P. Changing from 3.07 to 4.56, I needed carriers also. They set me up with new R&P's, master overhaul kits, and both carriers, shipped to CA, for $560. They were having some special for full kits front and rear. Around $420 before shipping and carriers, I think. You may not get the spare shafts as you would from the doner axles. I explored this but couldn't locate axles , in my area, that had 4.56 for a reasonable price. Even with a junk yard axle you'de need new bearing overhaul kits. Plus, I'm always worried about who used/abused the stuff before me. I know i can beat the crap out of my stuff, but I want to be the only person to beat the crap out of my stuff. That way I know what crap is left to kick
Black '99 4.0L 5-speed
3" BDS +1" body on 33" MTR's
Aussied 30/open 35 w/ 4.56's
Durango PS box/ JKS tie rod
RE Adj. Track Bar
Plus al the stuff to get me out of what I get into!
freedumb is offline
post #7 of 9 Old 04-12-2005, 10:33 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Swapping in a new carrier at $60 or so apiece should not be considered a big enough deal to affect any gear ratio decision. The carrier needs to come out anyway so using a different carrier to fit the desired ratio ring gear is nothing to allow to affect any gear ratio decision process.
Jerry Bransford is offline
post #8 of 9 Old 04-12-2005, 10:38 AM
red99tj
red99tj's Avatar
if your gonna go ahead w/4.10's, id say just do 4.56's...
Frank
red99tj is offline
post #9 of 9 Old 04-12-2005, 10:56 AM
freedumb
You might regret not doing it, later. I've got a freind who "knew" that he was satisfied with his 31", 4.11 combo...sure enough, a year later he was regearing again to fit 33's. Be careful not to under estimate the jeep bug.
RE Adj. Track Bar
freedumb is offline
Rubicon dana 44 ring pinion swap options AWESOME98TJ TJ Wrangler Technical Forum 6 05-28-2011 01:43 AM
Will ring n pinion from Scout Dana 30 fit in my tj? TJ_ITmgr TJ Wrangler Technical Forum 0 05-19-2009 10:22 PM
dana 30 ring n pinion question 4.7stroker YJ Wrangler Technical Forum 6 02-12-2008 08:25 AM
dana 30 ring and pinion spydermonkey YJ Wrangler Technical Forum 4 09-02-2006 01:32 PM
Ring and pinion 04 TJ dana 30 chiqo YJ Wrangler Technical Forum 2 01-25-2006 04:43 PM
