Quantcast Dana 35 - 27 spline chromoly shafts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Dana 35 - 27 spline chromoly shafts
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-30-2007, 08:33 PM   #1
Rickster
Dana 35 - 27 spline chromoly shafts...
Who's running these? How much did they cost you?
I'm looking to upgrade to get a slight amount more reliability but don't need a super 35 kit yet or a dana 44 or a ford 8.8 .
Thanks,
Rick
White 2004 TJ - 2.4 5 speed
31" BFG M/T's, 1" Daystar body lift, Rubicon Springs, Rubicon Express GEN 2 Discos, Bosch H4 Headlight Conversion, Hella 500 Fog Lights, Cobra 75 CB / 3' Firestik II, D30 aussie locker, jks mml, a.a. transfer shifter brkt., R.E. hand throttle, kilby skidplates
Rickster is offline   Reply With Quote
Old 03-30-2007, 08:37 PM   #2
FlexyTJ
I could be wrong- but the stock shafts are 27 spline?
[SIZE=2][COLOR=Navy]MK Motorsport & Fabrication
[/COLOR][/SIZE]
FlexyTJ is offline   Reply With Quote
Old 03-30-2007, 08:41 PM   #3
Rickster
they are, but not chromoly
-rick
Old 03-30-2007, 09:18 PM   #4
BoHeck
if you go 30 spline, you cant use your stockers as spares, right?
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System
BoHeck is offline   Reply With Quote
Old 03-30-2007, 10:22 PM   #5
j0nesy
no. the carrier is 30 spline and the stock 27 spline shafts WILL NOT fit into a 30 spline carrier
j0nesy is offline   Reply With Quote
Old 03-31-2007, 01:10 AM   #6
McLovin
1991 XJ Cherokee
There is only one company I am aware of that sells chromemoly 27 spline shafts. They are in quadratec cataloge. They are pretty spendy and only solve half the problem. Just as many, if not more, people break there carrier or spider gears.
McLovin is offline   Reply With Quote
Old 03-31-2007, 01:14 AM   #7
lupinsea
I picked up some HD 27 spline shafts and have been running them for 1.5 - 2 years now.
So far so good.
Here's the info on the shafts I ran:
Yukon Axle and Gear Part Numbers:
Left D35 Axleshaft - YA M35C-27-L-HD
Right D35 Axleshaft - YA M35C-27-R-HD
Supposedly the bump strength by 15-20%. Not the same as a Super 35 (30%+) but better than stock and reasonably cheap.
Including shipping I got them for about $100 / shaft through http://www.dc4wd.com. Prices may have changed since then. Be sure to verify you're getting HEAVY DUTY 27 spline shafts. They're not too common since everyone usually goes for the 30 spline stuff (which requires a different carrier).
There may be other HD chromoly 27 spline shafts out there, though. Look around.
- Jay
lupinsea is offline   Reply With Quote
Old 03-31-2007, 01:32 AM   #8
McLovin
1991 XJ Cherokee
So far so good.
A few years ago Yukon did make 27 spline 4340 shafts. not anymore though. Now the heavy duty shafts are made out of a slightly stronger then stock material. I don't think they are much, if any stronger then stock.
Old 03-31-2007, 07:49 AM   #9
Airborne4X4
1979 CJ7
I believe it was Yukon that said they discontinued the production of the hd shaft because they were still junk. Save your money and go 30 splines or just buy extra 27 spline shafts to replace them as they snap.
Chrome can get you home, you can signal the search aircraft with it!
Airborne4X4 is offline   Reply With Quote
Old 03-31-2007, 12:23 PM   #10
McLovin
1991 XJ Cherokee
I don't think anyone called them junk. I think they discontinued them because the super 35 kits became more affordable. Alloy USA sells there 30 spline shafts for 100 apiece. Superior has said that they stopped making the 4340 27 spline shafts because the failure rate was to high. I.e. they had to many warranty returns.
Old 03-31-2007, 10:52 PM   #11
Airborne4X4
1979 CJ7
Ok, it was Superior's axles that were junk.
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
