dana 300 swap!! - Page 3 - JeepForum.com
post #31 of 74 Old 04-12-2013, 09:26 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
The problem with the 231/300 is the length of the case once it's all together. I tried a black box-i bolted to a Stak D300, which is just as long as a stock 231. Unless you stretch the rear axle way back, it's too long of a combination especially when used with a TT skid.
Mail crawling.
MisfitSeven is offline
post #32 of 74 Old 04-15-2013, 01:38 AM
cavscout187
...the 300 to a 231 doubler is within an inch of my stock 231 why would you need to stretch?
cavscout187 is offline
post #33 of 74 Old 04-15-2013, 04:00 AM
rda616
Because having a longer driveshaft is a huge plus when doing a tt as already stated. The 231 was also used in half ton ram pickups and has had a good, long service life it those. Case failure can often be attribute to something else failing and causing the case to fail. Lack of maintenance, high mileage and excessive use contribute to these failures.
Not a fan of the d300 myself. It isn't a very smooth operating t case being it isn't synchronized. And by the time you by a clocking ring, 4:1 kit, 32 spline output and a rebuild kit you are $1300. into it. If you buy the stak flip case, there's another $700. If you double, there's another $500.
Sacrificing smooth operation for a near nonexistent strength issue is a bit silly isn't it. If you have fears of breaking your 231j then throw in a six pinion planetary and a wider chain and gears.
rda616 is offline
post #34 of 74 Old 04-15-2013, 04:16 AM
cavscout187
Ive snapped the chain three times since i did my 5.9 swap twice its been jbs wide chain so there is a strength issue.
post #35 of 74 Old 04-15-2013, 04:33 AM
rda616
There is something wrong with your case ,or bearings, or something else than. I have had a 5.9 for 3 years now with no issue. I'm still running the narrow chain as well.
rda616 is offline
post #36 of 74 Old 04-15-2013, 04:53 AM
cavscout187
Ive got quite a bit done to mine im putting down 516 ft lbs and 435 hp at 3100 I've got intake, rhs heads ported and polished, domed piston's compression at 11, performance tuned through bg Chrysler and twice the chain broke the case so im on my third. 231
post #37 of 74 Old 04-15-2013, 05:09 AM
cavscout187
Plus your forgetting a tera low for the 231 is 1200 plus the wide chain is 350... already more and no twin stick and weaker
post #38 of 74 Old 04-15-2013, 05:38 AM
rda616
There would be the problem. You aren't running anywhere near a stock 5.9. In this case it does make sense to upgrade to a gear driven case.
Look at the stack flip case. IIRC they fix a lot of issues with flipping vs a stock case. You will still need a donor for internal parts, but it may be your answer.
http://www.stak4x4.com/Dana_300/replace-a-case.htm
rda616 is offline
post #39 of 74 Old 04-15-2013, 06:04 AM
cavscout187
I got a 300 already from an 80
post #40 of 74 Old 04-15-2013, 06:58 AM
rda616
With that much tq you are really going to want a 32 spline jb conversions output as well.
rda616 is offline
post #41 of 74 Old 04-15-2013, 07:27 AM
cavscout187
Yup actually going with the no novack setup
post #42 of 74 Old 04-15-2013, 08:03 AM
freeskier93
I suspect you'll be not better off with a D300. With those numbers I'd seriously be looking at an Atlas.
Everyone is quick to say the D300 is gear driven therefore it's automatically stronger. I've honestly seen a lot more broken D300 gears on the various forums than busted 231s. Really the only time I've seen a 231 grenade is when the front CV joint seizes up due to improper maintenance.
freeskier93 is offline
post #43 of 74 Old 04-15-2013, 08:43 AM
cavscout187
Advanced adapters told me he rate them the same. And terra low 4:1 kits suck that's the gears you see tanked.
post #44 of 74 Old 04-15-2013, 08:52 AM
cavscout187
Plus I'm going off my buddies cj 7 he has a supercharged ls in there with a lame power robbing auto but it's pretty built and his Dana 300 has held up every time we go out
post #45 of 74 Old 04-15-2013, 10:24 AM
Desertwheeler
My flipped D300 has held up fine for over 6yrs and i'm not easy on the throttle at all...Stock 4.0 tho
2000 TJ Crawler- 5.5 lift w/14in coilovers, HP44, ARB, Cromo's, 300m Joints/D60, Detroit, D80 35spl shafts. Full hydro, OBA, OBW, Flipped D300 W/4:1 kit, custom cage etc.
2001 Cherokee Sport, 4.5 RC Longarm, 33 Duratrac's, SYE, 4:56's, Front HP30 w/Lockrite, Autopals- Sold
Desertwheeler is offline
dana 300 , transfer case , swap
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 05:38 PM
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 03:36 AM
Dana 44 swap out or regear the dana 35? nathanielt TJ Wrangler Technical Forum 17 05-06-2009 09:23 AM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 11:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
