dana 300 swap!! - Page 2 - JeepForum.com
post #16 of 74 Old 09-14-2010, 08:23 PM
JeepnBlake
There is also a 2.46 gear set for the D20 if you have a little time and $100
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #17 of 74 Old 02-17-2011, 10:32 PM Thread Starter
husbandjw
Have finally completed the Dana 300 install. I am working on the full write up and compiling pictures. Sorry it took months to get this started but, have been a little tied up at work.
husbandjw is offline
post #18 of 74 Old 02-18-2011, 04:16 AM
Boundless
congrats look forward to your write up
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #19 of 74 Old 02-18-2011, 07:57 AM
lstcj7
x2
Yeah you can make it, let me get my camera first
lstcj7 is offline
post #20 of 74 Old 02-18-2011, 08:05 AM
liveanadventure
dana 300 flipped is a very nice set up but as i found out it wont work with a turbo 350 trans front out put hits trans pan ,,,,,, i saw this cable shifter mount set up on line .. ii was going to do this may be it will help
liveanadventure is offline
post #21 of 74 Old 02-18-2011, 08:06 AM
liveanadventure
more
post #22 of 74 Old 08-22-2011, 09:35 PM Thread Starter
husbandjw
Ok. So I refuse to do the write up until I'm satisfied with the transfercase. However the flip kit spacer that is also your new mount fir the shift rods is aluminum. The case and lid are steel. No matter how many times and what variance I take.... It will not stay sealed for more than two weeks. I believe this is a combination of two things. 1. The expansion rates are different so with time it creates a gap in between the case/spacer/lid. 2. The transfer case is clocked downward. The lid or inspection cover (whatever you like to call it) had a drain hole that per down east offroad's instruction is drilled and tapped. This allows for a new vent. The vent is on the low side. The oil sling is on the low side. I believe the oil is actually clogging the vent tube. I actually get oil out of the vent tube from time to time. So when this happens I think it's pressurizing the case an blowing the seal. I am making a new lid out of .250 2024 aluminum and tapping a new hole in the top of the case. Does this sound reasonable or am I way off base?
post #23 of 74 Old 08-22-2011, 09:37 PM Thread Starter
husbandjw
Sorry for the long winded blah. I was wondering dies any know where you can order cable like that pictured above?
post #24 of 74 Old 08-23-2011, 04:38 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
North west fab makes a cable set for it.
The previously posted set was home built from midwest control cables and rod ends.
ratmonkey is offline
post #25 of 74 Old 08-28-2011, 09:18 PM Thread Starter
husbandjw
Im not really looking for a whole kit just cables. Any recommendations?
post #26 of 74 Old 08-29-2011, 09:41 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Read pirate for details.
post #27 of 74 Old 08-29-2011, 12:16 PM
DerekXJ
Ive heard great things about this swap, but also that they leak like crazy because they have to be flopped. As i see, your beginning to try and find a solution for this!
DerekXJ is offline
post #28 of 74 Old 04-12-2013, 02:50 AM
cavscout187
Did you ever figure this out?
cavscout187 is offline
post #29 of 74 Old 04-12-2013, 09:11 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
A couple of people on here are running 231/300 doublers. Remko on the build section is (only one I can remember) and I plan on it in the next year or so. It is not that the 231 is a weak transfer case ( I mean, they were installed in every tj and most xjs and how many are still running today), it is the 231's alminum case that is prone to breaking or cracking. The 300 is gear driven which makes it stronger than the chain driven 231, but that just means the chain is the weak link.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #30 of 74 Old 04-12-2013, 09:47 AM
cavscout187
Yeah I have been researching found a few ways people did this just wondering if the op ever figured it out
dana 300 , transfer case , swap
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 06:38 PM
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 04:36 AM
Dana 44 swap out or regear the dana 35? nathanielt TJ Wrangler Technical Forum 17 05-06-2009 10:23 AM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 12:42 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 02:17 PM
