Dana 30 torque specs - JeepForum.com
post #1 of 17 Old 08-05-2008, 10:44 AM Thread Starter
base shakers
I've found conflicting information after searching so I thought I'd ask here. What is the torque spec for the ring gear bolts and bearing caps for a Dana 30? i've heard the best way to tighten the ring gear is in a cross pattern in 10ft-lb increments. correct? Also, backlash should be 6-10 thou, right? thanks.
'05 LJ, ~4" lift, 35X12.5 Toyos, 16" beadlocks, HPD44, HPD60, 4-speed Atlas, 4.6L stroker
base shakers is offline
post #2 of 17 Old 08-05-2008, 11:11 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
55 ft-lbs for the ring gear bolts, tightening then in a star pattern is good. 60 ft-lbs. for the cap bolts, make sure the caps go back on in the same position and orientation they came off. Do NOT forget to apply Locktite to the ring gear bolt threads. And yes, that is the correct amount of backlash.
Jerry Bransford is offline
post #3 of 17 Old 08-05-2008, 11:17 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Jerry - you sure about 55 ft/lbs?
I just helped a buddy with a front lunchbox locker install and we did 80 ft/lbs.
The FSM says 70-90 ft/lbs for the particular year FSM that I'm looking at ('98).
Wheelin98TJ is offline
post #4 of 17 Old 08-05-2008, 11:27 AM Thread Starter
base shakers
thanks jerry. your numbers match up with the yukon setup specifications but i've seen different numbers on a number of on-line write ups. sounds like the FSM is a little different as well. and yes, red loctite is your friend. i heard about a guy who got fired from a shop because he didn't follow the spec, a ring gear bolt worked its' way out and destroyed a good portion of the front end.
post #5 of 17 Old 08-05-2008, 11:35 AM
Jerry Bransford
Administrator
I usually just refer to the Randy's Ring & Pinion chart I have bookmarked that lists pretty much all the axles our Jeeps use and 55 ft-lbs. what it says for a Dana 30. I'd probably be more inclined to go with the FSM though and now that I think about it, the FSM does say what you said.
post #6 of 17 Old 08-05-2008, 11:54 PM
garthbrown
There are two sizes of ring gear bolt available for the D30. The smaller bolts go to 55 ft/lbs. and the larger ones to 80 ft/lbs.
Speaking from experience, if you try and torque the smaller bolts to 80 ft/lbs, the threads come off. I can't tell you how not-wonderful that feels.
I don't recall the two bolt sizes, off the top of my head - they went larger over time.
1981 CJ-7
1959 Willys Wagon L6-226
1955 Willys Wagon SBC
garthbrown is offline
post #7 of 17 Old 08-06-2008, 06:34 AM Thread Starter
base shakers
My '05 FSM is stating 80 ft-lbs. i guess i'll go with that!
post #8 of 17 Old 08-06-2008, 09:18 AM
Scotch740
Scotch740's Avatar
Thats what I went for during my aussie install, and started to strip one bolt. Got it to 70 ft-lbs and called it good.
CLEAN THE BOLTS AND HOLES BEFORE TORQUING THEM! I didn't do that and thats probably what my problem was.
Scotch740 is offline
post #9 of 17 Old 08-06-2008, 09:50 AM
Jerry Bransford
Administrator
This thread reminded me that there was a ring gear bolt size change which explains the torque differences. Anyone know when that size change happened?
post #10 of 17 Old 08-10-2008, 10:24 AM
rqukrawler
Just buttoned up my D30 front Aussie install on my 99 GC. Manual said 70 to 90 ft-lbs for the ring gear bolts... I took them to 80 and everything snugged up nicely.
99' WJ Laredo, owned since day 1, hand-me down after 110k of groceries and soccer games, 4.0 Selec-trac, IRO 4" LA, IRO Sliders, discos, Rubicon Wheels & 255/75-17 BFG MT's
Another one bites the dust. Slow roll on Swamp... body is toast but the goodies will live to see another day.
rqukrawler is offline
post #11 of 17 Old 08-10-2008, 11:41 AM
garthbrown
At one point, I tracked it down via FSMs "for future reference" - but I'll be darned if I can find it now. Apparently, I filed it away somewhere "safe".
Most FSMs don't show actual bolt size, but the torque will tell you.
For the OP - as long as you're using the original carrier and the new ring gear bolts are the same size as the old ones, use whatever your FSM states.
1981 CJ-7
post #12 of 17 Old 04-21-2009, 05:28 PM
gaucho919
anyone know the year split? Im about to do an aussie install in my '96 HP D30 tomorrow and dont wanna strip bolts thanks
"The journey is the destination"
gaucho919 is offline
post #13 of 17 Old 05-26-2014, 08:08 AM
mrcleanjeep
i just installed a locker and torqued RG bolts to 90lbs and streteched 2 bolts. Thinking 80 max and using loctite. had a friend loose his bolts and made a mess of things.
mrcleanjeep is offline
post #14 of 17 Old 05-26-2014, 11:58 AM
freeskier93
I would stick to 55 ft/lb with loctite. That's what my Nitro install book says for D30. The gears I set up have been running perfectly for nearly 2 years... If 55 ft/lbs provides enough clamping force on the ring gear then there's no reason to increase it even with bigger bolts.
Typically FSMs list torque specs for DRY bolts, where most install books specify the use of loctite and, my guess, is their torque spec accounts for that, hence the lower torque.
freeskier93 is offline
post #15 of 17 Old 05-26-2014, 02:13 PM
bnine
I've never geared a d30 that didnt use 3/8 bolts. Maybe they exist, but I've never seen one.
Whenever possible go with the FSM.
Toque around the clock in 5-10lb increments. Do not try and get 80 lbs before your third or fourth lap. Thats how you end up breaking them off.
55 is light. Sure it might hold fine, but it is light.
bnine is offline
Dana 30 Torque Specs Provojeep YJ Wrangler Technical Forum 7 03-19-2013 05:14 PM
Dana 30 Torque Specs ech0sh4y YJ Wrangler Technical Forum 10 07-04-2010 06:17 AM
What are the torque specs for Dana 35 Cover Bolts? BWFBezerk TJ Wrangler Technical Forum 5 03-08-2009 07:54 AM
dana 35 torque specs 89yjmudman YJ Wrangler Technical Forum 2 01-12-2009 07:00 PM
torque specs on dana 30 bearing caps??? eng4safd YJ Wrangler Technical Forum 2 03-19-2007 04:44 PM
