dana 30 swap?? - JeepForum.com
post #1 of 3 Old 07-12-2010, 09:35 AM Thread Starter
joeskyline06
dana 30 swap??
i found a dana 30 out of an Grand Cherokee for 60 bucks at a junk yard, its still in really good shape, but i couldnt find the gear ratio on it, does anyone have any idea what it might be? also would it be a direct swap to put under my 02 tj or would i have to weld new brackets and mounts to it like say an 8.8? thanks for the help!
joeskyline06 is offline
post #2 of 3 Old 07-12-2010, 09:47 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
what year Grand Cherokee? why are you replacing your LP D30 with another LP D30?
if its a ZJ, its probably 3.73 or 3.55. but some ZJ's used CV joint axle shafts...you don't want those. and if its a ZJ, the unit bearing is probably different than yours. if its a WJ, it just won't work without lots of welding brackets.
check here for more info: http://www.jeepforum.com/forum/f13/z...u-post-880249/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 3 Old 07-12-2010, 12:16 PM Thread Starter
joeskyline06
well, im not really wanting to, its just that it is a hell of a deal, i was hopeing it would have 4.10s in it because thats what i am wanting to go to, around where i live you cant find any hp dana 30s because they all get picked clean as soon as they hit the junk yard, i have found a place on the internet where i can order one for pretty cheap, but its just the housing, no axles or gears or anything. lookes like im saving up for one of those.
d30 , dana 30 , swap , 8.8 , bracket , ratio , gear
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 05:38 PM
Question about Dana 30 to G2 Dana 44 front swap snowcrash TJ Wrangler Technical Forum 31 04-08-2013 07:29 PM
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 11:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
swap dana 30 to dana super 30 Gaiver173 TJ Wrangler Technical Forum 7 07-16-2004 11:26 AM
