Dana 30 to High Pinion D30 Swap - Driveshaft? - JeepForum.com
post #1 of 9 Old 01-31-2010, 09:37 AM Thread Starter
Ghaniba
Doing a swap from a stock Dana 30 in a TJ to a HP Dana 30, does the swap require a new front driveshaft or does the stock one from the TJ fit it perfectly?
Thanks,
Dave aka Ghan
Ghaniba is offline
post #2 of 9 Old 01-31-2010, 09:46 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Thanks,
Dave aka Ghan
My stock TJ Front Shaft one bolted right up!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #3 of 9 Old 01-31-2010, 09:50 AM
mudmonkey2400
mudmonkey2400's Avatar
I would think the length would be better than before. With 4" of lift, and a ~4" higher pinion, seems like it would be about perfect as far as the length goes.
2000 TJ : RK 5.5" X-Factor Long Arm, 1.25"BL/MML, RE Monotubes, RK HD Steering, Warn M8000, Lock-Right D30, Detroit D44 w/4.88's, 35x12.50R15 Pitbull Rocker Radials
1990 MJ : 2.5L, 5spd, 2wd, short bed and bone stock.
mudmonkey2400 is offline
post #4 of 9 Old 01-31-2010, 10:39 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Yup, swap axle and stap shaft on. All is good.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #5 of 9 Old 01-31-2010, 05:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
My OEM one fit well...
Knuckelhead is offline
post #6 of 9 Old 01-31-2010, 05:16 PM
crusher242
Same here. While you have it out, replace your u joints and centering ball.
Hold onto something... Quick!!!
crusher242 is offline
post #7 of 9 Old 08-07-2011, 03:54 PM
TJinSoFLA
Sorry to steal the thread. I am installing the front HP D30 and I am having fitment issues with the front ds. Is there a technique to install it that I haven't tried yet? I have a 4" lift. I just removed my tc drop. Could that affect it?
TJinSoFLA is offline
post #8 of 9 Old 08-07-2011, 04:00 PM
Benderff
Benderff's Avatar
Bolt one end in and then the other end.
Benderff is offline
post #9 of 9 Old 08-07-2011, 04:09 PM
TJinSoFLA
Actually I got it in. Sorry for wasting ur time. I had to set it on the ground to get it to fit properly.
high pinion dana 30 swap - very long with pictures camper49 TJ Wrangler Technical Forum 47 09-13-2016 08:13 AM
High pinion dana 30 vs rubicon dana 44 mustgooverit TJ Wrangler Technical Forum 17 04-28-2011 01:20 PM
High Pinion Dana 30 JO3DIRT3 YJ Wrangler Technical Forum 15 05-31-2009 05:08 PM
Dana 30 Carrier Swap from High Pinion pendleton TJ Wrangler Technical Forum 7 07-24-2007 04:30 PM
High pinion dana 30 kpatrick TJ Wrangler Technical Forum 19 09-25-2005 06:24 PM
