dana 30 axle seal replacement without removing diff.. - JeepForum.com
post #1 of 3 Old 07-31-2010, 06:43 AM Thread Starter
slafferty
Can you replace the axle seal without removing the diff? Its on the short side? I told my friend you had to remove the diff but he dont think he has to.. he said he got the seal out with a long bar and all he did was remove the shafts... however he ruined the new seal while tring to put it in..
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #2 of 3 Old 07-31-2010, 07:03 AM
jpross81
No, the way the seal is made it will only press in one way, and that way is from the carrier side. Usually there is so much dirt and junk built up in the axle housing that you wouldn't want to try to push the seal in from the wheel side.
jpross81 is offline
post #3 of 3 Old 07-31-2010, 07:31 AM Thread Starter
slafferty
well my friends jeep is a yj he said he can remove the vacume disconnedt plate and put the seal in form there.. anyone know if this is correct?
MY BUILD THREAD
d30 , dana 30 , axle , seal , differential , replace , replacing
removing inner axle seal on the dana 35.... hints? Big-n-Broke-YJ YJ Wrangler Technical Forum 8 11-16-2014 07:40 AM
Looking for D30 axle seal replacement and Ball Joints Replacement Write Ups pfifer TJ Wrangler Technical Forum 1 04-14-2010 06:49 AM
Need Quick Help, Please: Dana 44 Axle Seal Replacement Tommy R TJ Wrangler Technical Forum 6 08-01-2009 11:00 AM
Dana 44 Axle Seal Replacement Hambone83 YJ Wrangler Technical Forum 1 05-31-2009 04:20 PM
Axle seal replacement - Dana 44 Kiwi Jeeper TJ Wrangler Technical Forum 9 03-15-2008 11:17 PM
