Dana 30 Alloy Chromoly axle kit with ABS? - JeepForum.com
post #1 of 3 Old 08-02-2009, 08:50 AM Thread Starter
J03_TJ
Got a question, did some searching but could not find what I was looking for.
For the record my ABS has been disconnected for 4 years due to my rear dana 44 upgrade.
Well, I just bought the Alloy Dana 30 front axle kit (27 spline). Question is will the shaft upgrade fit into my D30 axle and everything bolt up? My current axle has the ABS stuff (tone rings). Hopefully it will. has anyone else put this into a Dana 30 front that had the ABS stuff on it?
Thanks hopefully.
J03_TJ is offline
post #2 of 3 Old 08-02-2009, 08:54 AM
never monday
no problem upgrading. Remember to pull the sensors while your in there
never monday is offline
post #3 of 3 Old 08-02-2009, 11:55 AM Thread Starter
J03_TJ
Thanks, would you describe "pull the sensors" a little more. not sure what they look like or if they unplug from something.
Thanks.
J03_TJ is offline
Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up barry1me TJ Wrangler Technical Forum 14 06-29-2010 07:32 AM
Superior Axle Vers. Alloy USA Chromoly 98tjwrangler TJ Wrangler Technical Forum 12 02-24-2009 02:48 PM
Alloy USA Dana 44 Chromoly Axle Shaft Kit (12135) Kiwi Jeeper TJ Wrangler Technical Forum 12 03-17-2008 08:15 PM
Alloy USA D30 Chromoly Front Axle Shaft Kit DaSham58 YJ Wrangler Technical Forum 6 03-05-2008 12:41 PM
Alloy USA D30 Chromoly Front Axle Shafts ryne0149 TJ Wrangler Technical Forum 22 01-19-2008 09:24 AM
