D44 yoke strap/bolts...im guessing theyre not the same as D35? - JeepForum.com
post #1 of 10 Old 05-19-2007, 03:27 PM Thread Starter
BoHeck
I have completed ALL of my axle swap and SYE install except being able to bolt in the rear part of the drive shaft to the yoke differential.
My strap and bolts from the D35 dont work in it, and I tried going to the auto parts store and got new ones for dodge/jeep and they dont work.
My axle is from northridge4x4 and I've got a Tom Wood's shaft. The yoke is not threaded, do I need some sort of U-bolt kit or something?
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System
BoHeck is offline
post #2 of 10 Old 05-19-2007, 03:40 PM
TJ on the Rocks
TJ on the Rocks's Avatar
Yes , you'll need a u-bolt kit . I did the same with mine .
If i could find the NAPA part number right now I could hook you up but
i'm heading out the door
TJ on the Rocks is offline
post #3 of 10 Old 05-19-2007, 03:53 PM Thread Starter
BoHeck
i think i found it, if this works ill post the spicer part number
BoHeck is offline
post #4 of 10 Old 05-19-2007, 04:15 PM Thread Starter
BoHeck
2-94-28x u-bolt kit according to the spicer box i have
BoHeck is offline
post #5 of 10 Old 05-20-2007, 07:49 AM
TJ on the Rocks
Yes , that's the correct part number if You're gonna go with the Spicer U- bolt kit .
However , I'm going to recommend You go to NAPA and have them cross reference the Spicer part number to a their part number .
And then just go with the NAPA kit instead . They're better and cost less !
I found that the Spicer u-bolts are too hard , breaking them upon installation is all to common .
And , the threaded portion of them is too short .
I've had complete success with the NAPA kit , the entire u-bolt is heavier and the threads are longer .
To accurately answer Your original question ..........
The strap bolt kit from the 30 , 35 , & 44 are all the same .
The 35 has it's own yoke while the 30 & 44 yokes are identical .
Your axle was delivered with the stronger u-bolt style yoke .
I converted both of my yokes ( 30 & 44 ) to this better style .
post #6 of 10 Old 05-20-2007, 11:41 AM Thread Starter
BoHeck
ah i see, thank you. stronger is better
BoHeck is offline
post #7 of 10 Old 05-20-2007, 11:46 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They both use the 1310 series u-joint. A u-bolt kit isn't required but it is stronger than straps... even though few have problems with u-joint straps. That the OE straps and bolts are a different size between the OE yoke and new yoke is possible but they should still accept the same usual 1310 series u-joint.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #8 of 10 Old 05-21-2007, 09:10 AM Thread Starter
BoHeck
yup, i just snapped my spicer one putting it on. the nuts just kept turning and turning, and then snap. what am i supposed to torque these down to? i didnt feel like i was putting that much pressure on it so i figured i'd just stop when it got hard to turn.
BoHeck is offline
post #9 of 10 Old 05-21-2007, 09:44 AM
BluesMan
BluesMan's Avatar
Look in the box with any other parts you got from Northridge.
Dave put my new u-bolts and nuts in the box with the ARB stuff.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
post #10 of 10 Old 05-21-2007, 09:57 AM Thread Starter
BoHeck
thats exactly where i found them, they were just well hidden. wound up having to get the ones from NAPA anyway, just got done putting them on. one of the spicer ubolts snapped.
BoHeck is offline
Gas Tank Metal Strap Bolts MikNov TJ Wrangler Technical Forum 13 05-20-2009 06:41 AM
Stripped Yoke Strap bolts!!! Any Ideas?? Jarhead0861 TJ Wrangler Technical Forum 5 03-01-2008 10:16 AM
transfer case yoke strap 2nd YJ YJ Wrangler Technical Forum 3 12-28-2007 08:48 AM
Replacement Yoke to Strap bolts rbn1357 YJ Wrangler Technical Forum 5 12-18-2006 08:27 PM
Front DS Strap Bolts YJ-Mike YJ Wrangler Technical Forum 5 09-13-2006 08:00 PM
