D44 Rear shafts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > D44 Rear shafts
FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 04-21-2015, 08:52 AM   #1
Mousejockey
D44 Rear shafts
Looking for a set of spare shafts until I upgrade to chrome, Will the shafts from the D44 of a TJ/YJ/Grand Cherokee fit in an 04 rubicon? As I look at the spec sheets they all appear to be 30 spline
Mousejockey is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:27 AM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a TJ w/ discs, yes. not sure about the rest...but the Grand Cherokee is a D44a, it uses c-clips IIRC.....It's not a D44. totally different animal....
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 10:56 AM   #3
Jeepsr4me
As for spares, I think they same... You will have to change the ends if not disc brake set up like you have
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 12:02 PM   #4
joe_jeep
Wj 44a is weird, no good.
Yjs never came with a d44 In the us.
Std tj d44 shafts will work, shaft retainer are slightly different, need to b changed.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
