D44 Gear Problems, shaft problems. - JeepForum.com
post #1 of 8 Old 04-09-2008, 01:58 PM Thread Starter
lazerusrm
so i let a friend take my jeep to moab on easter weekend....
I ended up with some broken parts, The Ring gear in the rear is missing 10 teeth, and the drivers side axle shaft is twisted.
I've been looking for recommendations for upgrades/replacements, but im still not sure what i should get / where the best/cheapest place is to get the parts.
Can you guys make some recommendations? I would appreciate it very much!
Also of note i have a Detroit Locker in the D44.
Pics up in just a minute.
lazerusrm is offline
post #2 of 8 Old 04-09-2008, 02:14 PM
TJ Flexer
Never let that friend borrow your jeep....
John "BUZZ" Brownell Jr
2000 TJ "sahara"
PSC steering box skid, JKS Quicker Disco's, Riddlers front and rear, Rokmen gas tank skid, Nth degree oil pan skid, Nth degree D30 & D44 slider, 1" Currie Hvy Duty MML, 1" Prothane BL, CB
or see pics
TJ Flexer is offline
post #3 of 8 Old 04-09-2008, 02:15 PM
Jetscuh
O rly?
2015
^^ Agreed.
Jetscuh is offline
post #4 of 8 Old 04-09-2008, 03:42 PM
CCrew
Alloy shafts, new gears by the sound of it. I use David at Northridge, ( http://www.northridge4x4.com ) nothing but good things to say about him.
-Roger
CCrew is offline
post #5 of 8 Old 04-09-2008, 03:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Superior Axle makes good OE-strength replacement axleshafts, I think it's only $115 or so for a single shaft if you don't plan on upgrading to alloy shafts. You'll need new bearings (Timken SET-10), bearing retainer, and a seal too. A set of alloy axleshafts like from Alloy USA (my choice) or Superior Axle would be a nice upgrade.
Ring gears only gets replaced with a new matching ring & PINION gear, never by themselves. Installed, that's going to cost somewhere close to $500.
Getting
Jerry Bransford is online now
post #6 of 8 Old 04-09-2008, 05:44 PM
Coils Rule
-Roger
x2
David is the cheapest around and has your parts in stock.
Coils Rule is offline
post #7 of 8 Old 04-09-2008, 05:50 PM
skoke70
Originally Posted by Coils Rule View Post
x2
Northridge has good prices but dc4wd has cheeper prices
get a quote from both
1997 TJ SE, 175,000 5 speed. 8k on new engine. RE 4.5" long arm.1" PA BL, tera 4:1. 35"x12.5"x15" MTZ, fab tech front bumper, warn rear w/carrier. Currie rock sliders, D44 in rear w/ arb. 488 gears. TBT sports cage. currie tie rod.
skoke70 is offline
post #8 of 8 Old 04-09-2008, 06:29 PM Thread Starter
lazerusrm
Sweet. i Ordered a ring and pinion and Alloy USA rear shafts.
I'm doing the install myself, so i'll save a bit. i already have the whole thing apart.. just need the parts
THANKS ALOT!
problems taking out the axle shaft incagoldjeep TJ Wrangler Technical Forum 14 01-22-2010 07:24 PM
CV Shaft problems. DiabloYJ YJ Wrangler Technical Forum 6 08-31-2009 09:46 AM
Drive shaft / universal & 2nd gear downshift problems docdonnyb YJ Wrangler Technical Forum 14 07-05-2009 10:18 PM
drive shaft problems help!! muddyfun YJ Wrangler Technical Forum 8 11-28-2008 01:27 PM
Rear output shaft problems jp98_crawler TJ Wrangler Technical Forum 0 10-13-2008 08:25 AM
