#1 | |
D44 Front Questions
So, I'm looking at a D44 from a Rubi and was thinking. The axle does not come with knuckles, the seller states that I need to use my D30 knuckles and brakes. That got me thinking... could I use F150 knuckles and brakes to give me the 5x5.5" bolt center then be able to use Warn hubs? Are the Rubi axles the same at the ball joints as other 44's thus allowing for the F150 hubs? Do I need to change the short shafts when I do that, or will the stock Rubi shafts work with the F150 knuckles and hubs? Any other issues that I'm missing?
Thanks
Mine - 2004 Unlimited Red 4.0L, NV241 4:1, RE 5.5" Long Arm, 35's on Champion Beadlocks, MetalCloak fenders and front bumper, Hanson rear bumper, 4.88's, ARB's, Alloy 33 spline D44 shafts, HP44 front w/ WJ outers, D44 rear ... and to much more . RED JEEP CLUB #436 |
#2 |
Get a D30 HP housing if you go with 30 spline shafts, just as strong and gets your DS about 3" higher.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416 www.midatlanticjeepers.com |
#3 | |
Warn does make the kit to convert the front to 5x5.5 hubs but they cost nearly as much as building a real front axle to begin with.
2002 TJ SE 2004 WJ Laredo 4.7 2006 LJ 2007 Rockwood Freedom 2280 "...in the GOP, enthusiasm is measured in Reagan units." |
#4 |
Ok then, sounds like it is a pain to try and make it work. Thanks for the insite.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
