#1 | |
D44 F/R swap write ups?
I'm looking for some advice or a technical writeup for the rubicon D44 front and rear axle swaps.
Will I need to do anything with the drive shafts? For either or both the front or rears? Currently I have 30" tires. And will probably upgrade to either 32" tires at a later date. When that happens a RC 2.5" lift will also likly be installed. How does this impact the drive shaft? Thanks
#2 |
Misconfigured DNS
I did the same swap on my TJ in 2007, took two of us about three hours, pretty easy to do.
Used the stock rear drive shaft from the D-35 and adapted it to the Rubi D44 using a 1310/1330 combo u-joint (Spicer part# 5-134X) . I'll be putting a SYE in later, but for now it works. It's a very tight fit, not a lot of play left in the driveshaft, but it works. A SYE and new shaft is better, if it's in the budget. The front driveshaft had to be shortened about 1-3/4"s. I had it re-done at the same time to use the 1330 u-joint. I had read about problems with the brake lines and e-brake cables but had no issues there. I took the brake line/breather block off the D35 and it bolted right up to the Rubi D44 tube and hard lines. The e-brake cable routed and fit just like the originals, adjusted better than stock and holds with no problems. I also used the stock brake metering block under the hood, made no changes to the stock brake system, bled them out in just a few minutes. I don't have adjustable LCA's, just extended lower arms that came with the lift. For now they work ok, adjustable LCAs and a better set of UCAs are in the future but the driveline angle isn't that bad with no SYE (3.5" lift). I made a mount plate and put the pumps under the driver's seat. Also did the extra switch panel mod on the dash and have three switches, one powers the front/rear switches (a semi-safety thing so I can't accidentally engage the lockers at freeway speed. I'm running mine stock with 35's and have pretty well beat them up. I did twist the right-front outer off last year but no other issues, they've held up better than expected. A couple of tips: A skateboard was handy in positioning the axles under the Jeep. Rent or borrow a u-joint tool or be prepared to do the BFH and socket routine to get the old joint out. Took quite a bit of time to get them out without the right tool. Spray everything a few times with PB Blaster starting a few days before the swap. Drink beer after it's done. ![]()
San Diego JeepForum Section |
#3 |
How do I get some D44's F/R in my WJ
2001 GC With Mods 4.0, 242, select trac,truetrac's F/R, 4,11s,Kevlar's 255/75/17 on JK, IRO transfer case skid, JKS sway disconnects and alot of other things.TR Front bumper, Mile Marker PE8000 winch, PIAA 510 lights, custom front drive shaft,Clayton's LA 6" lift,4" Drop pittman arm, WJ Front Chromoly/U-Joint Axle Conversion, XM,Tom Woods SYE kit rear drive shaft, Rusty Intake, Cobra 75 WX ST cb, IRO sliders,from 93003 |
#4 |
Misconfigured DNS
Doable, but some work. Might consider some JK axles. One of the guys we wheel with down here did that swap on his WJ:
#5 | |
Does the front drive shaft need the same 1310/1330 u joint as the rear? Im curious without a lift will I need to shorten the rear axle as well? Would adding a 2.5" RC lift allow me to use the existing rear axle without having Drive vibes? What would happen if the lockers were actuated at highway speeds? Thanks |
#6 |
bump x10
c10 |
#7 |
Bump to ten chars
#8 | |
#9 | |
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs |
#10 | ||
Misconfigured DNS
More than likely you would need to shorten the rear shaft. I initially installed mine with a 4.5" lift and it was almost too tight. I've since gone to a 3.5" lift and have swapped in a Rubi t-case and SYE Quote:
![]() Maybe after I win the lottery
#11 |
The driveshaft needed to be shortened on the rear. The shop suggested they remove the rear yoke and replace it with a 1330 yoke so that it no longer required the combination u-joint it was about 20$ more to do this.
I found it interesting that they needed a u-joint installed in order to balance the drive shaft. It should be ready tomorrow afternoon. Install shouldn't take long at all and then out for a test drive. What type of grease should I use on the output shaft of the transfer case? |
#12 |
[QUOTE=StvDiego;7914418
I had read about problems with the brake lines and e-brake cables but had no issues there. I took the brake line/breather block off the D35 and it bolted right up to the Rubi D44 tube and hard lines. The e-brake cable routed and fit just like the originals, adjusted better than stock and holds with no problems. I also used the stock brake metering block under the hood, made no changes to the stock brake system, bled them out in just a few minutes. A couple of tips: A skateboard was handy in positioning the axles under the Jeep. [/QUOTE] Ok so quick question. What type of rear axle did you start with? I have a dana 35 with drum brakes and the e-brake cables from the drum brake look nothing like what is needed for the disc brakes on the 44. Can you post a picture of your disc brake cable? Also I used a furniture mover with 4 wheels. This made moving and positioning the axle a snap. ![]() |
#13 |
nice looking WJ. I agree the JK swap would make sense. same bolt pattern too.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#14 | |
You need parking brake cables for your rear disc brake application. The connection at the adjustable bracket mounted underneath the tub is the same as for drum brakes. A steel spring collar crimped to the cable sheath. They're kind of a pain to disconnect, so it wouldn't surprise me to know the previous owner just cut them out and ruined perfectly good cables. At the rear wheels, the attachment is different for drums vs. disc brakes. You can purchase the correct cables on internet sites like rockauto.com.
steve in central florida '98 TJ wrangler sport.....gunmetal blue XJ d30/rubicon TJ d44...33's with popular suspension mods want to read my build threads...they're long with lots of pictures |
#15 |
Yes disc brakes, rotors and calipers were included. Brake pads appear to be in good condition.
The rotors have a bit of surface rust on them. First tap of the pedal should nock that off just fine. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
