D44 disk brake backing plate - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > D44 disk brake backing plate
The Original 3/8" Ruffstuff Diff Cover!3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-26-2015, 11:09 AM   #1
dlysle
does the raised lip on the backing plate face in toward the diff or out toward the tire?
'You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you.' - Walt Disney, Animator, Film Producer
'four wheel drive only allows you to get stuck in more inaccessible places' - George Noll
dlysle is offline   Reply With Quote Quick reply to this message
Unread 08-26-2015, 11:49 AM   #2
RWKHaus
1990 XJ Cherokee
the lip faces in towards the diff.
Brook "He kissed me at KOH, you should ask him about it…"
RWKHaus is offline   Reply With Quote Quick reply to this message
Unread 08-26-2015, 02:40 PM   #3
mrblaine
Wizard of Brakes
mrblaine's Avatar
The backing plate is what the caliper bolts to that has the parking brake shoes attached to it.
There is a 4 bolt axle retainer that goes on top of the backing plate to hold the axle in.
There is a shaft collar that acts as a bearing retainer that presses onto the axle.
What one are you confused about?
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 08-26-2015, 02:58 PM   #4
RWKHaus
1990 XJ Cherokee
Come on Blaine. You know what he was asking. Or at least what it sure sounds like he was asking. There is only one item with a "lip" that can be mislabeled like that.
The axle shaft Seal retainer plate lip faces(protrudes) on the side with the axle seal (inward), on a common disc brake setup D44 rear axle.
Better?
Unread 08-26-2015, 03:40 PM   #5
mrblaine
Wizard of Brakes
mrblaine's Avatar
Better?
Actually I don't because there is a backing plate with a dust shield that has a lip on it that can be put on either direction.
And NO ONE would ever call a retainer a backing plate that expected a sensible answer.
No worries though, the next time you send me money for loaded backing plates for a disc brake conversion, I will remember this post and more than happily send over a pair of disc brake axle retainers along with a copy of this thread.
I strongly suspect your demand for accurate nomenclature will rise accordingly and in dramatic fashion.
I am Savvy
Unread 08-27-2015, 09:14 AM   #6
dlysle
i was asking about the retaining plate that holds the axle in. thanks for the help.
Unread 08-27-2015, 10:05 AM   #7
mrblaine
Wizard of Brakes
mrblaine's Avatar
The raised lip on the disc brake style axle retainer is exactly taller off the flat surface by the difference in thickness of the cast disc brake backing plate and the stamped steel drum brake backing plate. So, that means it has to point at the seal to keep the bearing in preload.
I am Savvy
