D35 took a crap! Repair carrier/spider gears or upgrade to D44? - JeepForum.com
post #1 of 21 Old 05-22-2012, 11:30 AM Thread Starter
HootenTJ
HootenTJ's Avatar
D35 spider gears shredded, broken carrier, and possibly need new ring and pinion. I have the 2.5L engine and one day would like to put in a I6 but that's not happening for a couple years. If I put in a super 35 kit would the 4.0 handle it or would I be setting myself up for a breakdown? Also if I decide to do the work myself would a basic home garage be able to do it or am I looking at special tools and equipment needed to swap carrier/spider gears? I've swaped my 2.5L engine before but have never tackled any axle work. Thanks for all feedback.
'97 4-Banger, 2.5L, 2" BBL, 4.10 gearing, 33x12.5 ProComp MTs, Custom Flat Fenders, Custom Front Bumper, Savvy Gas Tank Skid, 6,000LB winch
HootenTJ is offline
post #2 of 21 Old 05-22-2012, 12:14 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you looked for another d35 for cheap?...
Knuckelhead is offline
post #3 of 21 Old 05-22-2012, 12:23 PM
FarmerinVA
Originally Posted by HootenTJ View Post
D35 ... possibly need new ring and pinion
That's a big variable because it adds so much to the price and the time-out-of-service.
IMHO, new R&P is the clincher. Cost-wise, it's hard to justify the Super 35 kit if you are doing a new R&P at the same time. The Super 35 kit makes more sense if you are building in stages.
Plus there is the question of why you broke the D35 carrier. If it isn't a total fluke, the Jeep gods are telling you that you need a stronger pumpkin, not a second chance for the D35.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #4 of 21 Old 05-22-2012, 12:40 PM
hallsofstone
Ford 8.8 should not be ruled out of this decision. Tons of discussion on this topic (D44, S35, 8.8) if you use the search function. TJ D44's are not exactly easy to find.
In any event, this may be a good opportunity for you to regear.
Jeeping Ohio Every Day
00 TJ Sport - Ever evolving DD/Rig
85 Suzuki GS700 - ugly
K.C.C.O.
hallsofstone is offline
post #5 of 21 Old 05-22-2012, 01:05 PM
tdavid14
Consider this: most experienced folks here think putting an I6 in an SE is too hard compared to going all the way to a V8. So I would opt for the strongest axles you can afford.
tdavid14 is offline
post #6 of 21 Old 05-22-2012, 01:16 PM
SLADE
8.8 or Dana 44.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #7 of 21 Old 05-22-2012, 01:17 PM
cfmiller58
i went for the d44 when my pinion bearing went and only because it just happened to be available and came with a matching front end. if i had the time to do it id go 8.8
Black Jeep Society
cfmiller58 is offline
post #8 of 21 Old 05-22-2012, 01:18 PM
hallsofstone
What? I don't think that "too hard" is the case. More like "might as well go big since I have it apart anyway" is more like it. All the same, plenty of people drop in 4.0's after their 2.5's crap out.
K.C.C.O.
post #9 of 21 Old 05-22-2012, 01:48 PM Thread Starter
HootenTJ
HootenTJ's Avatar
Can I assume if I decide to go with a Ford 8.8 I would need someone to weld on jeep TJ brackets for the control arms and shocks? I was checking out a bolt on application but quadratec seems pricey for a D44 that's direct bolt on. Again though, is this something I can accomplish in my garage at home with basic tools and will I need a machine shop help or special tools?
HootenTJ is offline
post #10 of 21 Old 05-22-2012, 01:51 PM
liredneck
If you looking at 44s from q-tec might as well check out an 8.8 from ECGS . I got mine with 4.10 and a lock right bolt in ready for around $1500 I think
97 tj 6 cyl 5 SPd 4" supelift 35" baja claws 8.8/hp 30 ,4.10 lockrite in the rear , RR sye and adams dc shaft ,10k lb viper winch and other crap
liredneck is offline
post #11 of 21 Old 05-22-2012, 01:52 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yes, the 8.8 will need setup for the TJ coil and link suspension.
Or you can buy ready to bolt in 8.8 axle assemblies from East Coast Gear Supply.
Wheelin98TJ is offline
post #12 of 21 Old 05-22-2012, 01:59 PM
hallsofstone
Keep an eye on CL for any D44 options that might pop up. You might get lucky like cfmiller58. If I had a turdy-5, I'd be looking at the ECGS 8.8 setup for sure.
K.C.C.O.
post #13 of 21 Old 05-22-2012, 04:21 PM
Strings72
Bought a 57k 8.8 freshened it up and had it under the jeep for 450$ plus I have 4 wheel disc... 8.8 all the way, show me a tj Dana 44 for that money and ill eat my 8.8. Start at one rotor and chow down the whole way to the other
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #14 of 21 Old 05-22-2012, 04:36 PM
MayRoll
x2. If you're going to have a new 8.8 or 44 built gear to 4.88.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #15 of 21 Old 05-22-2012, 04:48 PM
merkchop
I would look around for a used D35, they are cheap if you find one and a lot easier to find than a D44. You can probably run across one out of a 4 banger with the same gears so you would not need to regear.
Biggest question with yours would be if your R/P is bad, if so then you are getting into a lot more money, then comes up the question of gearing better. If you do that, since you are already buying it all and setting it up anyway, you will need to do the front as well, so then you are buying 2 sets of gears and set up.
As for special tools if you do it yourself, yes you will need a few to set up the gears.
merkchop is offline
axle , d35 , d44 , differential
carrier pin/spider gears play vince21 TJ Wrangler Technical Forum 0 10-12-2011 09:02 PM
dana 35 carrier and spider gears 3fifty TJ Wrangler Technical Forum 6 07-06-2011 06:08 PM
Spider gears blown, What upgrade now? ffsmo TJ Wrangler Technical Forum 10 06-11-2006 12:03 PM
Old spider gears in new carrier? GKTJ TJ Wrangler Technical Forum 3 01-03-2006 01:04 AM
stock carrier/spider gears 86comanche TJ Wrangler Technical Forum 1 07-21-2005 07:49 PM
