Is a D35 really that weak? - JeepForum.com
post #1 of 16 Old 03-12-2006, 12:57 PM Thread Starter
bmboll
I have done a lot of reading about how you shouldn't buy a jeep with a D35 if you are going to wheel it with bigger tires and a locker. Does that apply to 33" tires and a LSD?
What I want to do is a 3"- 4" lift and 33" tires. I have a D35 with the factory LSD. I also have 3.07 gears. This is mostly a semi DD. I wheel it maybe 6 times a year. I would say the hardest trails are about a 6 to 7 out of 10. (Anyone in the Tucson, AZ area agree that Chivo fall is about a 6 or 7?)
The reason I question the lack of strength of the D35 is this-
If I'm not mistaken, a fullsize chevy Blazer has a D44 in the rear. My buddy has one and he has a 4" lift and 33" tires. He has not had any problems. That vehicle has got to be a couple thousand pounds more than a Jeep. I would think the same set up on a jeep with a D35 should be good.
What do you all think?
bmboll is offline
post #2 of 16 Old 03-12-2006, 01:13 PM
acorn
One example comes immediately to mind. There's a fellow in my club who wheels regularly (every chance he gets) with his D35. He has the factory LSD and 33's on 4" of lift. He is fairly conservative with his use of the throttle and has had no trouble out of his axle.
That being said I'll point out that we are wheeling in the Ozark Mountains and you are in the Southwest. The different terrain may have an impact that I don't understand.
In my opinion and limited experience the Dana 35 is not the best thing DC ever did for us, but it is not an egg (or a turd).
'01 TJ Sport - 5 speed 4.0 - 31X10.5 Kumho MTs and 3.07s
JKS BL & BMML - JKS Quicker Disconnects
Warn front bumper - Nth Oil Pan & Warn Steering Skids - Homebrew Hand Throttle
Coming soon: 4.11's - OME HD
Black Jeep Club #105
acorn is offline
post #3 of 16 Old 03-12-2006, 01:35 PM
M&C_TJ
M&C_TJ's Avatar
yelp i am putting 5.5 on my jeep with the same curside 35 while stock i ran the HELL out of her with no problems the way i see it and experinced it is if you take care of her but then again some people get that lemon 35 and snaps pulling out of the driveway and some wheel hard with it. its all how you take care and with the type of wheeling and how often there should be no problem.
M&C_TJ is offline
post #4 of 16 Old 03-12-2006, 01:39 PM
Coynster
The bottomline with a D35 is, its not IF, but WHEN. I've gone through two of them, both with mild wheeling. If your doing moderate wheeling and NOT locking your rear end, it should treat you fine, just watch your wheel spin. The minute you decide to put a locker in, or start hopping on your rear end, your asking for trouble...
Coynster is offline
post #5 of 16 Old 03-12-2006, 02:33 PM
sctigerjeep
pictures are worth 1000 words right?
http://www.billhughes.com/dana35c/
'98 Sahara, RE SF 4.5" lift, 33x12.5 BFG MT's, PSC front bumper w/ Warn M8000, TKH Fab Rear Bumper/Tire Carrier, AtoZ Fab rockers, Aussie Locked D30, Ford 8.8 Rear w/ Trac Lok, 4.10's, TBT Sport Cage, Currie HD Steering, Eaton Beadlocks, CO2 OBA, Etc.
sctigerjeep is offline
post #6 of 16 Old 03-12-2006, 02:43 PM
Pat98TJ
I broke 2 D35s in the same day. Both at 1100 rpms. A direct bolt in Dana 44: CLICK
Pat98TJ is offline
post #7 of 16 Old 03-12-2006, 03:04 PM
jeep loser
I gotta say it's a good axle
Just like the AMC 20 it's not without it's faults, but there's always something better. I had a amc 20 I swapped out the axles for one piece ones and threw in a locker put on some 33s and ran the hell out of it. no problems. The point is I fixed the weak link.When the d35 replaced the 20 everyone cheered. now it's a bad axle? No, but there are better ones out there. I have some advice don't bounce on the gas. Because if the axles don't break something else will. Next time someone says "dana 35s are weak" or so on. Tell them a Dana 44 is nothing next to a Dana 70. Or a 2 1/2 ton Rockwell .
5 % of people make things happen
65% of people let things happen
30% of people say "what happened?"
jeep loser is offline
post #8 of 16 Old 03-12-2006, 03:34 PM
chewrocks
I ran an open D35, 3.07 and 32 MTs for several years. Mines a DD plus mountain trails, dunes and 10 days in moab with no problems. But I am a conservative wheeler, easy on the throttle and always try to pick the smoothest line.
On the otherhand, a friend of mine with a similar set up and is a maniac behind the wheel, hard on the throttle and just points it and goes has broken several axle shafts.
After regearing mine to 4.56 I started worrying about the added torque to the axles so I decided to put in a super kit with ARB. Then I figure I have the gears and bigger axle shafts, the jeep has a total of 6 inches of lift (which made the 32s look pretty small) so I put a set of 35s on it. Wish me luck.
chewrocks is offline
post #9 of 16 Old 03-12-2006, 03:56 PM Thread Starter
bmboll
I had an 89 Bronco that had 3.0? gears in it. It was an 8.8" rear and had 35" tires. It was a dog on the street but it did everything I asked it to do in 4 lo. I have a 78 Bronco now that has 3.7? gears. If I were to part it out how hard would it be/ how much money would it take to put them on a Jeep?
bmboll is offline
post #10 of 16 Old 03-12-2006, 04:25 PM
otisdog
2008 WK
At a minimum get a set of spare axles and carry the tools to put them in. Also know how to do it. Sure as heck if you don't have the stuff you will snap one on the trail. As a matter of fact it's probably only a question of WHEN, not IF you will snap one with 33" tires doing 7 rated trails. I have seen them go for years doing tough stuff and others snap when turning a corner on the street.
33's and 3.07 gears are going to be hell together. When you decide to regear think about putting a Super 35 kit in or just getting a D44 or a Ford 8.8. These both can be bought ready to bolt in.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #11 of 16 Old 03-12-2006, 05:25 PM
Torquemeister
I broke my dana 35 running over a 2X4
Torquemeister is offline
post #12 of 16 Old 03-12-2006, 05:59 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
I broke mine on the street, open with 31"s.
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #13 of 16 Old 03-12-2006, 06:18 PM
dllbert
dllbert's Avatar
Did you notice how each of the failures that show the insides of their "bad" D35 appear to have been neglected in terms of regular maintenance?
It seems like every time I've been with someone who has had a breakdown, they either ignored warning signs or were doing something silly.
I think axle weakness is only partially to blame, mostly it has to do with the way you drive.
I've done the Rubicon (end-to-end) and a fair amount of Fordyce on my D35 (31" tires, LS)...both 5+ rated, plus a lot of muddy fire trails while hunting. No troubles as of yet...
dllbert is offline
post #14 of 16 Old 03-12-2006, 07:20 PM
1BadJeepX06
D35's hold up just fine. Reguardless to what people say. I mean they are no D44 when it comes to the heavy stuff, but I've seen 4" of lift with 35's and 100,000+ miles out of em.... Not just road queens either... One guy I know specifically wheels his every chance he gets and is no pushover while offroad... He goes through the deep ****...
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #15 of 16 Old 03-12-2006, 07:25 PM
Spartan302
Spartan302's Avatar
d35's are trash, its that plain and simple.
Spartan302 is offline
Weak AX-5? 4biY YJ Wrangler Technical Forum 14 11-03-2009 09:43 AM
Is the D35 THAT weak? AustinCJer TJ Wrangler Technical Forum 20 08-31-2009 08:14 AM
Please say my JK is not this weak? medicbear JK Wrangler Technical Forum 22 06-03-2009 06:19 PM
Weak OEM AC... help! jeepcrd2010 TJ Wrangler Technical Forum 5 07-16-2007 08:22 AM
Is it weak to have....... TJnTN TJ Wrangler Technical Forum 17 08-02-2003 12:26 PM
