D35 locker in a D30 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > D35 locker in a D30
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 06-29-2010, 03:24 PM   #1
Farmkid
D35 locker in a D30
Finished up about 2hrs ago. I put my Detroit EZ-Locker out of my D35 into my D30 front end. Works perfectly with no problems. Has the normal sounds of a lunchbox locker but nothing that is unbearable. Going on a big ride this weekend can't wait to see how she does on the hills.
Farmkid is offline   Reply With Quote
Unread 06-29-2010, 03:26 PM   #2
RaggedOleMan
Am I missing something? Something's not right here...or, you're a magician!
RaggedOleMan is offline   Reply With Quote
Unread 06-29-2010, 03:43 PM   #3
Farmkid
The only difference between a D35 and a D30 is the axle gears on a D35 are cut out for C-clips. Everything else is identical
Unread 06-29-2010, 04:02 PM   #4
EricRollerSkate
There is nothing correct regarding that statement.
EricRollerSkate is offline   Reply With Quote
Unread 06-29-2010, 04:05 PM   #5
EricRollerSkate
Can you guess which one is the D35?
As for the ez-locker. I don't know.
Unread 06-29-2010, 04:33 PM   #6
jeepinmichguy_
No longer a Jerk....
jeepinmichguy_'s Avatar
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Unread 06-29-2010, 04:46 PM   #7
TJ311
Actually all axle parts are interchangeable with a big enough hammer. I just put my Ford 8.8 axle shafts in my D35 to save time on doing the whole swap. Lots of lube and a really big hammer. Plus, now I have a disc AND drum brakes in the rear!
TJ311 is offline   Reply With Quote
Unread 06-29-2010, 04:48 PM   #8
EugeneTheTJ
Keep Chopping
EugeneTheTJ's Avatar
yall didnt know this? I put 14 bolt shafts in my D35. I call it the extremely super 35
EugeneTheTJ is offline   Reply With Quote
Unread 06-29-2010, 04:54 PM   #9
Farmkid
WTF A@# holes. OK THE SPIDER GEARS AND AXLE GEARS ARE THE SAME. You guys are just jealous because I got sense enough to figure things like this out.
Unread 06-29-2010, 05:02 PM   #10
jeepinmichguy_
Axles
Dana 30 (181 mm) - 1997-2006
* Front axle used on all TJs except the Rubicon model
* Stock gear ratio options = 3.07, 3.55, 3.73, 4.10, 4.56
* Carrier break = 3.55 / 3.73
* Open carrier - no Trac-Lok limited slip option
* Ring gear diameter = 7.2"
* Ring gear bolts = (10) 3/8 x 20 RH
* Low pinion (short pinion)
* Pinion shaft diameter = 1.376"
* Pinion shaft spline count = 26
* Axle shaft diameter = 1.16"
* Axle shaft spline count = 27 both inner and outer
* Axle shaft u-joints = 5-760x / 5-297x
* WMS-WMS = approximately 60.5"
* 5 on 4.5" bolt pattern
Dana 35c (194mm) - 1997-2006
* Standard rear axle used on all TJs except the Rubicon model
* Carrier break = 3.31 / 3.55
* Optional Trac-Lok limited slip differential
* Ring gear diameter = 7.5625"
* Ring gear bolts = (8) 3/8 x 24 RH - NOTE: 7/16" x 20 RH used on later model TJs
* Low pinion
* Pinion shaft diameter = 1.406"
* Axle shaft diameter = 1.18"
* Rubber pressed-in fill plug
ΜΟΛΩΝ ΛΑΒΕ
Unread 06-29-2010, 05:07 PM   #11
jeepinmichguy_
just cause it fit doesnt mean its going to work correctly. there is a reason they have different p/n's from the manufacturer though.
ΜΟΛΩΝ ΛΑΒΕ
Unread 06-29-2010, 05:10 PM   #12
Mean Max
Don't poke the bear
Mean Max's Avatar
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 06-29-2010, 05:11 PM   #13
Farmkid
This isn't the first time. There are a couple of buddies of mine that have done this in the past with no problems. I've drove mine around for about 45min this evening. I even took it threw a ditch to flex it to see if it would stay locked in. STILL NO PROBLEMS.
Unread 06-29-2010, 05:12 PM   #14
jeepinmichguy_
i always judge my work after 45 minutes to something like that may work on the road but flexing it in a ditch i would not call an accurate test of durability under stress. honestly i think if your buddys have done it then you didnt think of it right? sp which statement is true? i really doubt they did it anyway but to each their own. not my jeep not gonna be my problem.
i call these conflicting statements
ΜΟΛΩΝ ΛΑΒΕ
Unread 06-29-2010, 05:18 PM   #15
Farmkid
Dude whatever. If I were you I'd be mad to..........
dana 30 , dana 35 , locker
