D35 Fill Plug leaking?!? - JeepForum.com
post #1 of 5 Old 04-24-2008, 07:12 PM Thread Starter
JeSimmers
JeSimmers's Avatar
Sorry for the dumb question, but why is my D35's fill plug leaking? Had a regear done about 5000 miles ago. Was going to change diff flud and noticed the cover is wet. Thanks in advace!
Red Jeep Club Member #454
JeSimmers is offline
post #2 of 5 Old 04-24-2008, 07:20 PM
raskull
raskull's Avatar
If you're sure it's leaking from the plug, go ahead and pull it, clean the plug, and the fill hole, and put it back in.
If that still doesn't work, you may need a new plug. Your jeep is getting older now and the rubber might not be soft enough to seal properly.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #3 of 5 Old 04-24-2008, 07:24 PM
240
That rubber fill plug is the worst idea....I'm sure it saves Chrysler a bunch in production costs.
I'd try a new plug.
240 is offline
post #4 of 5 Old 04-24-2008, 07:48 PM
paulthejeeper
paulthejeeper's Avatar
I'd try a new plug.
x2... considering your rig is a 97, and maybe its likely the plug is original
(now 11 years old) buying a new one is a cheap fix...
Yeah I take it offroad...my scratches have scratches!!!
03 BRIGHT SILVER METALLIC,TJ,
4.0, auto,
4" rough country lift,
33" baja claws,
black 15" crawler rims,
more mods as budget allows...
JUST EMPTY EVERY POCKET
USN JEEP CLUB MEMBER HULL#61
BRIGHT SILVER METALLIC JEEP CLUB MEMBER #61
paulthejeeper is offline
post #5 of 5 Old 04-24-2008, 08:15 PM
redjeepjunkie
i had to buy a new one. they wanted 7 bucks for that damn thing at the dealer
97 jeep TJ, 4"lift, 31"tires OllllllO
redjeepjunkie is offline
ox locker fill plug size and fill level? brinoff YJ Wrangler Technical Forum 1 06-14-2010 08:18 AM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
Rock Crusher fill plug leaking sb127 TJ Wrangler Technical Forum 4 05-20-2007 08:47 PM
Leaking fill plug on D35 4cylYJ YJ Wrangler Technical Forum 11 06-24-2005 04:35 PM
