D30 Replacement Options? - Page 4 - JeepForum.com
post #46 of 48 Old 04-03-2009, 07:20 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by never monday View Post
it that's the case. swap in or buy new bushings. Plate the pass upper mount and lowers. You can build a truss cheap. Heck I think the T&T truss is under 150.
It's like $160 without any UCA Mounts (and you have to cut off the existing ones to get it on there, so you have to do something)
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #47 of 48 Old 04-03-2009, 09:09 PM
Greg_Volkman
Originally Posted by SuperWade2 View Post
I don't, but I'm sure I can find someone who does.
i took mine to the local car wash
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #48 of 48 Old 04-05-2009, 05:09 PM Thread Starter
SuperWade2
SuperWade2's Avatar
In order to get the passenger side axle shaft off, the tube had to be cut off. I didn't see it (Had a club member assisting and he finished before I could see it), but he said the shaft was pinched against the housing about 1/2 way up where the smile was, but didn't appear to be bent (had it been OEM and not Chromo I think it would have been worse. Splines and everything looked great...
SW2
2017 WK2 Overland
Sentry Key Replacement Options (I only have 1 key!) Boilermaker52 TJ Wrangler Technical Forum 38 07-19-2009 12:48 PM
top replacement- options paroxysym TJ Wrangler Technical Forum 3 03-15-2007 07:50 AM
AX5 replacement options. superjoe YJ Wrangler Technical Forum 4 06-27-2005 06:46 PM
Tie Rod/Steering Replacement Options mkuzmukerau TJ Wrangler Technical Forum 15 02-09-2005 02:33 AM
Transmission replacement options phoen1c1an TJ Wrangler Technical Forum 2 11-24-2004 06:57 AM
