D30 parts salvage - JeepForum.com
post #1 of 6 Old 08-12-2008, 08:24 PM Thread Starter
Grim Jeeper
Grim Jeeper's Avatar
D30 parts salvage
I have a "spare" D30 from a when I swapped axles with better gearing, 4.56, and an ARB D44 rear a couple months back.
The D30 and broken D35 have been sitting on my garage floor for months and it's time get rid of them.
Is there anyting I should keep from the old D30? Anything prone to breakage that I should hang on to? Or should I just sh*t-can the whole thing and be done with it?
I'm pulling the D35 shafts for Craigslist, but don't know if the front shafts have any value for me or on the used market.
Thanks
If a Dana35 axle shaft breaks and no one is there to hear it...does it make a sound?
Grim Jeeper is offline
post #2 of 6 Old 08-12-2008, 08:43 PM
alvinl
alvinl's Avatar
I paid just over $100 for a pair of D30 inner and outer shafts shipped to my house. They should be worth something for trail spares to someone. If you put them in the for sale section for $100 I bet they would sell pretty quick.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein
alvinl is offline
post #3 of 6 Old 08-12-2008, 11:30 PM
Greg_Volkman
I pulled my shafts/hubs, knuckles, rotors, pads, brass breather fitting and even the ball joints (less than a year old) from the old housing. I will probably pull the carrier and the carrier bearings, hone the inside of the carrier bearings out to use as a set-up set for installing gears and do the same with the pinion.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #4 of 6 Old 08-13-2008, 03:33 AM
Jeepguy1977
Jeepguy1977's Avatar
I'd think you'd want to keep the shafts, the knuckles, and maybe the bearings as Volkman mentioned. Oh, unless you think you might need a carrier at some point.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #5 of 6 Old 08-13-2008, 10:57 AM Thread Starter
Grim Jeeper
Okay, so I pulled the the carrier and bearings and will hang onto them, as well the as the shafts. What this about the knuckles? Do they commonly break?
If I was carrying trail spares what would make the most sense to carry? Is left or right side shaft more likely to break than the other?
post #6 of 6 Old 08-13-2008, 01:59 PM
Jeepguy1977
I don't think the knuckles break, but if you haven't gone to a HPD30, then you have them should you decide to build one
Jk Salvage Parts moparradar JK Wrangler Technical Forum 14 06-12-2011 04:35 PM
What Parts to Salvage dirtbagofva TJ Wrangler Technical Forum 20 05-14-2007 06:48 PM
CO Salvage Yards for TJ parts 10HSD TJ Wrangler Technical Forum 4 02-23-2006 12:12 AM
salvage parts in Northern California? paulchilds YJ Wrangler Technical Forum 3 05-28-2003 02:41 PM
