D30 limited slip? - JeepForum.com
post #1 of 25 Old 11-29-2007, 01:39 PM Thread Starter
brkshr
brkshr's Avatar
D30 limited slip?
Can anyone recommend a limited slip for my D30. This is my DD, but I definately need something in the front for offroad. I always get stuck at least once a trip.
brkshr is offline
post #2 of 25 Old 11-29-2007, 01:43 PM
Chris_
Get an auto locker.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #3 of 25 Old 11-29-2007, 01:57 PM Thread Starter
brkshr
brkshr's Avatar
Oh and money is an issue, so it needs to be worth the cost/effectivness
brkshr is offline
post #4 of 25 Old 11-29-2007, 02:03 PM
joburnet
Aussie Locker, $250 or so. I don't have one but it's on my Christmas wish list.
joburnet is offline
post #5 of 25 Old 11-29-2007, 02:04 PM
Giviner
Giviner's Avatar
For the price you will utimately spend to get a limited slip installed, you might as well save up a bit more and get a selectable locker. Way better for off-road then flip a switch and you're back to normal for street driving. It's a decision you will not regret spending an extra few bucks on.
I run an Auburn ECTED in my D30 and it is a limited slip when not locked.
2003 TJ Sahara
2010 WK
Giviner is offline
post #6 of 25 Old 11-29-2007, 02:56 PM
BILL G
BILL G's Avatar
Detroit Tru-Trac.I have them F+R.
BILL G is offline
post #7 of 25 Old 11-29-2007, 02:58 PM
2005X
i have the detroit tru-trac for the front, kinda wished i would have gotten a locker
2005X is offline
post #8 of 25 Old 11-29-2007, 03:00 PM
JJs99TJ
I would say go with an Aussie, $249, free shipping and a
pretty easy install.
http://northridge4x4.com/proddetail....od=AL-XD-13027
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #9 of 25 Old 11-29-2007, 03:16 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
To pre-address the likely concern the OP may have about installing a locker in the front axle, it's a 100% non-issue for the Wrangler TJ as a front locker is virtually transparent in 2wd on the street. This is because there is no torque being sent through it to the wheels when you're in 2wd do it does not affect anything or even let you know it's there. Only in 4x4 does it "do it's thing".
There is FAR more benefit to a front locker than there is a front limited slip differential in a Wrangler that is taken offroad. When I ran Truetrac LSDs front and rear offroad, they were nearly useless and totally ineffective the vast majority of the time. Their main benefit is on the street in ice or snow conditions.
Personally, I would go for a Lockrite up front. The Aussie works the same way, is a copy of the Lockrite, but is made in Australia and I prefer buying American-made whenever I can. There is no difference between them so far as their design and how well they work goes.
Jerry Bransford is offline
post #10 of 25 Old 11-29-2007, 03:20 PM Thread Starter
brkshr
brkshr's Avatar
Thats a new one on me, do you run a locker up front. I would much rather have a locker if I can.
brkshr is offline
post #11 of 25 Old 11-29-2007, 03:24 PM
Jerry Bransford
Administrator
Absolutely, I don't wheel with anyone who doesn't and most of us drive our TJs on the street. I installed and drove it for years without problem, and well before I installed manual hubs up front and whether my front hubs are locked or unlocked, the locker is never even noticeable. A Lockrite might click once in a while but that would be the most you'd ever notice. You won't feel it through the steering wheel at all in 2wd, and you won't until you shift into 4x4.
The only time a front locker in a TJ is not a good idea is if you have to drive in 4x4 on the streets like during the winter and there is snow or ice on the ground.
post #12 of 25 Old 11-29-2007, 03:34 PM
CNY
Lock Right locker up front is invisible in 2WD, and it's great in 4WD.
Best investment (other than tires) I have made, when it comes to increasing the capabilities of a TJ.
Easy to do yourself, if you have a set of tools. The stuff you learn while installing it will be worth knowing, if you do your own maintenance on the Jeep.
Oh, and in an answer to the question in your sig line......
That quote is from a poem written by Cliff Burton. It was used in the Metallica song "To Live Is To Die", which is a tribute to their bassist Cliff, who died in a bus accident.
CNY is offline
post #13 of 25 Old 11-29-2007, 04:25 PM
SecondTJ
SecondTJ's Avatar
I've got the Detroit TrueTrac limited slip in front and love it. But it is not cheap unless you find them used.
If you are going for cost, a lunchbox locker would be best.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #14 of 25 Old 11-29-2007, 04:38 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Don't forget that you'll need at least a partial gear setup with any limited slip.
A lunchbox locker you can install yourself.
Wheelin98TJ is offline
post #15 of 25 Old 11-29-2007, 04:43 PM Thread Starter
brkshr
brkshr's Avatar
whats a lunch box locker
brkshr is offline
Limited slip... more like limited thinking 1dirtywhyjay YJ Wrangler Technical Forum 12 04-17-2009 07:08 AM
Anti-Slip / Limited Slip HELP!!! mtb1981 JK Wrangler Technical Forum 3 05-18-2007 07:06 AM
Limited Slip?? Pipedrummer TJ Wrangler Technical Forum 42 04-30-2007 08:21 PM
? about limited slip in D35 cspoffroad TJ Wrangler Technical Forum 11 04-27-2005 05:57 PM
Limited Slip SpitNine TJ Wrangler Technical Forum 5 11-01-2002 06:59 AM
