D30/D35 pinion seal replacement - JeepForum.com
post #1 of 20 Old 06-22-2008, 02:19 PM Thread Starter
raskull
raskull's Avatar
The seal is leaking on both my diffs, where the driveshaft goes into the diff. The pinion seal I assume..
I did a little reading on replacing these and there is info about needing an inch pound torque wrench, and pre-loading the bearings to 300+ ft lbs..
Is this something I need, or can I replace these seals on my own? I can buy new seals from napa for about $20 each, so if I can do it myself I'd like to avoid taking it in. I don't have a torque wrench that goes over 100 ft lbs, and I don't have a press for the bearings.. am I **** out of luck?
I can likely borrow a large torque wrench (up to 700 ft lbs) if needed from work, and I have a press at work if needed.. but I'd prefer to do it in the garage.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #2 of 20 Old 06-22-2008, 02:32 PM
Bigsam
I did mine on my own. I used an impact to get the nuts off to remove the yoke. I used a breaker bar with a pipe to put them back on. It has been over a month have done wheeling and lots of driving and have had no problems. I did not do anything with my bearings though.
Bigsam is offline
post #3 of 20 Old 06-22-2008, 02:50 PM
TheMightyGoat
The "correct" way to do it is to replace the bearings and crush ring and install a new pinion nut torqued to the factory specifications and all that other stuff that no one ever does.
The way everyone does it is to take the thing apart, throw a new seal in there and tighten it up to around 190 ft/lbs. To get my pinion nut off, I ended up sticking a jack under a 1.5" bar to break it loose. You'll be fine.
Might not be a bad idea to invest in a decent torque wrench, though.
TheMightyGoat is offline
post #4 of 20 Old 06-22-2008, 02:52 PM
otisdog
2008 WK
You set the preload with an INCH LB torque wrench, not 300 ft lbs!
There's a crush sleeve in both those diffs and you are supposed to measure the preload before you pull the pinion nut then when you reassemble you set the preload to the same + 5 inch lbs.
Better do some more reading on this. If you overcrush that sleeve your diff won't be working right very long.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 20 Old 06-22-2008, 03:21 PM Thread Starter
raskull
raskull's Avatar
Jim
Hey it's not my words, it's others. Looking at different write-ups online they state the pinion nut should be put on anywhere from 150ft lbs to 300 ft lbs.. seems the most common used for a d30 as an example is about 160ft lbs-220ft lbs.
"and the Dana handbook calls for 200-220ft lb."
Anyway, I did see someone saying that if you mark where the pinion nut was before, and replace it to the same spot + 1/16th of a turn it should be very close.
Anyone ever tried this?
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #6 of 20 Old 06-22-2008, 03:35 PM
jake1977
Jim
X2! I had mine replaced and that's all it took. Yes that preload is crucial! Get the preload to tight you cannot simply back off the nut to the correct preload. The crush sleeve will have to be replaced. That means entire disassembly.
jake1977 is offline
post #7 of 20 Old 06-22-2008, 04:07 PM
CHRRRIS
CHRRRIS's Avatar
I'm using this write-up to do my D30 pinion seal in the next day or so.
http://www.jeepingsingles.net/tech/pinionseal.asp
Written by a buddy of mine and it seems very straight forward..
Except the torque upon re-installing the nut, that I do not know..
It's easier to go down a hill than up it but the view is much better at the top.
-Henry Ward Beecher
Current - '98 Black Z28 with some goodies
Previous - '97 Gun Metal Blue TJ
Northern Illinois Extreme Jeep Club
CHRRRIS is offline
post #8 of 20 Old 06-22-2008, 04:36 PM
Nonya
I see a expensive garage visit in your future.....DO NOT follow that write up,look in the forums for the proper info.
The info in that link you posted is so GENERAL its just enough info to get you in so deep you'll have such a mess you won't know what to do.
Nonya is offline
post #9 of 20 Old 06-22-2008, 04:37 PM
Nonya
there ya go
Nonya is offline
post #10 of 20 Old 06-22-2008, 04:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
300 ft-lbs. is only if you're crushing a new crush sleeve. 160-180 ft-lbs. is fine if you're not. I asked Tom Wood this question many years ago and that's what he said which was good enough for me when I was replacing a seal and swapping to a u-bolt pinion yoke style. That ft-lbs. amount has worked fine the 3-4 times I've done it the past 7-8 years.
Jerry Bransford is online now
post #11 of 20 Old 06-22-2008, 04:43 PM
CHRRRIS
CHRRRIS's Avatar
What is so general about it besides there not being a torque spec for the pinion nut?
I don't see any reason for the job to be any more difficult than it states..
Some of you guys (otisdog) are mentioning measuring the preload to know where the nut needs to be upon re-installation.. That is not mentioned in the write-up, which is why I said that is what I am still looking around for the right answer on..
Besides re-installation, removal of the old seal looks to be very simple.
Edit: As Jerry said, 160-180 ft. lbs... Following that write-up and tightening down the nut to 160-180, where is the bad in this?
-Henry Ward Beecher
CHRRRIS is offline
post #12 of 20 Old 06-22-2008, 04:51 PM
Nonya
Once the crush collar is installed it is IMPOSSIBLE to use it again....forget about it.THERE IS NO TORQUE SPEC FOR REUSING THE CRUSH COLLAR!Because its useless once its been crushed.The proper method is to mark the nut and retighten 1/16 inch past the mark.ANY OTHER method is useless IMO.I've done 100's of rears that others have "replaced the pinion seals"trust me on this.
Nonya is offline
post #13 of 20 Old 06-22-2008, 04:55 PM
TheMightyGoat
Every time this subject comes out there's always the "you have to do it right" crowd and the "throw it back together and tighten it" crowd. I don't think any of us who identify with crowd B would claim their approach to be "right", but at the same time most people come around to the good 'nuff side at the end of these debates and I've yet to hear from one of them who toasted a pinion assembly doing so.
post #14 of 20 Old 06-22-2008, 05:00 PM
Jerry Bransford
Administrator
If the 'Do it Right' crowd says you have to go by the book which means a new crush sleeve which means the pinion gear has to be pulled, then count me out of that crowd. I doubt many would claim Tom Wood's advice is anything but unimpeachable and that's what I go by when replacing a seal or yoke.
post #15 of 20 Old 06-22-2008, 05:03 PM
imbezol
imbezol's Avatar
And how do you take this magical and exact 1/16th of an inch measurement? Is it the amount the outside edge of the pinion nut rotates? Do you use the corners of the nut or the flange of the nut? Are they all the exact same diameter?
imbezol is offline
rear pinion seal replacement? 70ssclone TJ Wrangler Technical Forum 3 12-15-2008 08:23 AM
D30 pinion seal replacement jeep_chinto TJ Wrangler Technical Forum 9 03-13-2007 08:20 PM
pinion seal replacement Muddeprived TJ Wrangler Technical Forum 38 09-07-2005 04:56 PM
Pinion seal replacement boomhower YJ Wrangler Technical Forum 3 08-10-2005 08:37 AM
Pinion seal replacement Polaris TJ Wrangler Technical Forum 6 06-06-2003 12:05 AM
