cylinder misfire again - JeepForum.com
post #1 of 4 Old 03-16-2014, 02:05 PM Thread Starter
monahan
lright heres the story...2006 2.4L started running stupid (sputtering, gargling, backfiring, especially in low RPM ranges), check engine light came on, cylinder misfire. similar thing happened about 5 years ago that was solved by new plug wires. thought maybe they somehow went bad after 60k miles so i bought a new set. this mostly fixed the problem for about a weekish (when i say mostly, i mean normal driving habits were back to normal, but if i tried, say, starting from second, or putting it in 4th while going 20 mph, the sputtering would return). but after about 10-15 days it returned to running crappy all the time. i thought maybe its the plugs themselves, but due to another issue i did not immediately change them (i had a feeling the last plug change resulted in some stripped threads and i wanted to try that last just in case i needed to drop in a helicoil). so i bought a new coil pack...maybe a slight improvement but still nothing fixed...finally convinced it was the plugs, i swapped them out (no stripped threads, whew!). but the same thing happened again... mostly fixed the problem for 1-2 weeks, but now its back to running stupid again.
i'm sort of a newbie here so i'm not sure what else to try. any help would be appreciated.
thanks
monahan is offline
post #2 of 4 Old 03-16-2014, 03:32 PM
JBTJ
Which plugs did you install?
JBTJ is offline
post #3 of 4 Old 03-16-2014, 09:00 PM Thread Starter
monahan
bosch platinum
monahan is offline
post #4 of 4 Old 03-17-2014, 06:36 AM
JBTJ
Might want to try Champion or Autolites. I've heard of a few guys having problems with those.
JBTJ is offline
backfire , cylinder misfire , spark plugs , sputtering
