Cylinder, fuel injector, exhaust, white smoke - JeepForum.com
post #1 of 9 Old 07-26-2014, 02:13 PM Thread Starter
bbarkhuff
I have a TJ Wrangler.. couple weeks ago my engine light came on, went to diagnosis it, came back the following:
number 3 cylinder, high fuel pressure, injector, and a couple other codes with in this notion.
i have changed out the spark plugs and number three was completely black, burnt out. put a new one in and ran fine for a week. light came back on ran the diagnosis again, same codes.
before changing out the injector I put in a injector cleaner before my last fill up hoping to clear the problem, but didnt. Replaced the old injector with a new one and still doing the same thing. I have been running it to help clear the code, but no luck.
No leaks
rough idle, white smoke, smell of fuel.
bbarkhuff is offline
post #2 of 9 Old 07-26-2014, 03:09 PM
Dave02TJ
Could be getting coolant in that cylinder, worth a look.
Remove plug after letting the the vehicle sit for awhile after a run.
Get a really bright flashlight and look through the spark plug hole, bring the piston up to tdc to have a look.
just my first idea, I have many lol.
Dave02TJ is offline
post #3 of 9 Old 07-26-2014, 03:11 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is your engine consuming coolant? White exhaust is normally from coolant... often from the coolant getting into the engine via a blown head gasket.
Jerry Bransford is offline
post #4 of 9 Old 07-26-2014, 06:21 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Or a cracked head...
Knuckelhead is offline
post #5 of 9 Old 07-26-2014, 09:42 PM Thread Starter
bbarkhuff
thanks guys. i will run those by my father and take a look at it. very helpful
thank you
post #6 of 9 Old 07-27-2014, 09:42 AM
GilaMtnJeep
GilaMtnJeep's Avatar
A cooling system pressure test coupled with a compression test will answer the white smoke question.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #7 of 9 Old 07-27-2014, 10:25 AM Thread Starter
bbarkhuff
checked com. all cly. are at 160 = or - 5 tested with all plugs out. put a new plug in #3 drove it about 5 miles miss comes back pull the plug and it is all black new injector in #3. what do you think about the coil pack good or bad? lots of strong fuel when this happens.can the coil pack be tested?
post #8 of 9 Old 07-27-2014, 10:29 AM
GilaMtnJeep
It is possible the the coil pack could be bad. Not sure if you can swap with a good one or not but that would confirm it if the problem moves. Check the boot, too. A torn or punctured boot can cause a miss fire as well.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #9 of 9 Old 07-27-2014, 12:07 PM Thread Starter
bbarkhuff
all boots are in good condition. no tears or punctures. everything is firing. so far no white smoke upon starting and revving in place.. will take it for a test drive and see what happens. you guys are big help test drove it lots of white smoke going to do a pressure test on cooling system. why would
compression test come put good if gasket is creaked and not using water?
