Cylinder 6 Misfire - JeepForum.com
post #1 of 4 Old 02-25-2010, 05:14 PM Thread Starter
ramil89
Cylinder 6 Misfire
Hey guys,
My glorious check engine light came on...again. Before it came on and said I had a cylinder 6 misfire, so I replaced all of my spark plugs, wires, distributor cap, and rotor. It ran smoother for a couple of days, then the engine light came back on and it feels "laggy" or it hesitates when I drive. I have a bad clutch as well that I'm replacing on Sunday, but I'm trying to distinct the difference between my engine and clutch problems. I went to my local Oil Can Henry's today for them to plug in the diagnostic tester, and what do you know- cylinder 6 misfire again. I'm confused on what else can be done, or what my other problems could be. I obviously have a inline 6, 4.0L engine. Thanks in advance!
ramil89 is offline
post #2 of 4 Old 02-25-2010, 05:30 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Originally Posted by ramil89 View Post
Hey guys,
Problems I have seen before that caused a 0306. Exhaust leak, bad plug, bad valve, bad plug wire, bad injector.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #3 of 4 Old 02-25-2010, 06:06 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
X2... and that would probably be the only thing.How many miles on motor?Try switching the plug and the wire.I know it's a pain in the *** but you can get bad one of each.You could always pull a compression check also.
GOLENJEEPTJ is offline
post #4 of 4 Old 02-25-2010, 07:08 PM
Gonda
What did the plug look like that you took out of #6? Can you post a pic?
Gonda is offline
Cylinder 5 misfire WVMIKEsTJ TJ Wrangler Technical Forum 16 02-16-2015 07:34 AM
# 5 cylinder misfire??? 79K-10 TJ Wrangler Technical Forum 4 10-28-2009 07:16 PM
Misfire on cylinder 3....not sure what else to do simplybao TJ Wrangler Technical Forum 11 08-10-2008 09:44 AM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
Cylinder Misfire? fundabug TJ Wrangler Technical Forum 5 02-11-2007 02:45 PM
