cv and no sye - JeepForum.com
post #1 of 5 Old 04-12-2014, 06:38 PM Thread Starter
Wrangler_Boy97
cv and no sye
hey guys, eventually i want to get a sye and cv because i want to do a tummy tuck and a larger lift. however, that is not in my budget at the moment. what are the ups and downs of running a cv with no sye, if thats even possible? by the time this goes in i will have a 2" coil lift and will have temporarily dropped the tc (untill i get a sye..or cv driveshaft??)
Wrangler_Boy97 is offline
post #2 of 5 Old 04-12-2014, 07:29 PM
Gunner13
Not possible. One it would be two long without the sye. And two there is no way to attach it. Unless you have a rubi. Whole different story for the rubi
Gunner13 is offline
post #3 of 5 Old 04-12-2014, 08:00 PM Thread Starter
Wrangler_Boy97
alright, thanks, i guess ill be saving up for the pair then
post #4 of 5 Old 04-13-2014, 02:04 PM
biffgnar
biffgnar's Avatar
It actually is possible. There are driveshafts out there that add a double cardan joint but retain the slip yoke on the TC side of the double joint. Is it a good idea though? Not really. The double cardan to axle portion of a shaft setup that way gets so short that dealing with the angle can be a pain. Also doing the SYE, besides fitting the new driveshaft, shortens the TC (so lengthens the driveshaft) and strengtens the tailhousing/output of the TC.
biffgnar is offline
post #5 of 5 Old 04-13-2014, 07:24 PM
CharlieHo
Don't forget the control arms you'll need, as well.
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
budget , cv driveshaft , lift , sye
