Cutting the metal bracket near the speakers in the dash - JeepForum.com
post #1 of 6 Old 07-15-2010, 05:21 AM Thread Starter
johny84
Hello all,
I wanted to ask if anyone has cut out the metal bracket from the TJ dash to allow a larger speaker ? Does anyone know if this will the damage the vehicle in any way or compromise anything ?
Thank you!
johny84 is offline
post #2 of 6 Old 07-15-2010, 06:19 AM
gabriel05
Just watch for wiring and I don't think it should be a problem. Check this out
ROCKCRAWLER.com - 33 Engineering 5 1/4 Speaker Adapter Plates for TJ
I don't think the company that makes that bracket is around any more but that should give you an idea of some options. I've even seen people mod the factory speaker and use it as a bracket for the larger speaker size. Google and the search function are your friend.
Black Jeep Society Member
gabriel05 is offline
post #3 of 6 Old 07-15-2010, 06:42 AM Thread Starter
johny84
First, thank you for your response.
I did see the stuff on google, but I wanted to check around here for some more info and experience. The bracket seems to be important, and the fact is that in later TJ models it was not removed but moved to different location.
I already have the 5.25 speaker adapters for the front..Just wanted to check again before I remove it.
johny84 is offline
post #4 of 6 Old 07-15-2010, 10:30 AM
rs4race
I removed mine. I havent had any problems with it since.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #5 of 6 Old 07-15-2010, 11:09 AM
rastadog
rastadog's Avatar
2011 JK Wrangler
...cut mine too. I can't imagine it has any structural effect.
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #6 of 6 Old 07-15-2010, 11:11 AM
4xfiend
4xfiend's Avatar
I cut mine out to fit larger speakers. No problems at all. I made my adapters out of a cutting board I got for $.99 at Ikea.
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | Poison Spyder BFH rear bumper | Rokmen Mercenary rockers |
Originally Posted by Jerry Bransford
I DON'T FRIGGIN' CARE!!!
Originally Posted by Jim M
Please keep the facts to yourself; nobody here wants to hear them. This was a perfectly good internet argument until you came along with anecdotal evidence.
4xfiend is offline
speaker , tj , wrangler , front , metal bracket , bracket , cut , cutting , issue , problem
Sharp metal cutting my tires Toms87 YJ Wrangler Technical Forum 7 09-14-2009 08:13 AM
Cutting Speaker Hole in Dash... jesseleikerjeep YJ Wrangler Technical Forum 6 05-28-2009 01:39 PM
Swapping metal dash Mark455SD YJ Wrangler Technical Forum 11 05-21-2008 08:07 PM
RBQ radio - mopar ipod install - is that metal bracket needed? scrapple TJ Wrangler Technical Forum 1 01-28-2007 11:49 AM
Non-Metal CO2 bracket? elmo510 TJ Wrangler Technical Forum 4 04-06-2006 08:54 PM
