Cutting fender flares - JeepForum.com
post #1 of 3 Old 09-06-2011, 05:07 PM Thread Starter
sdptrey
I have a 05 tj rocky Mtn. edition. I want to cut the fenders. Trying to make them flat cutting the part that slopes down. I know you can do it on the jk. Has anyone done this do you have any suggestions. Any help would be great.
Thanks
sdptrey is offline
post #2 of 3 Old 09-06-2011, 05:13 PM
djfuzzy
I haven't but it sure seems to me like a dremel and a good eye would get the job done.
Sent from outer space
USMC 2006-Present
2000 TJ - some stuff
djfuzzy is offline
post #3 of 3 Old 09-06-2011, 06:17 PM
TonysTJ
A dremel will work but it also makes a mess and it's not as simple as a boxcutter. I marked where I wanted to cut, scored it with the box cutter, bent it and it peeled right off.
TonysTJ is offline
No Cutting Fender Flares jhumphrey YJ Wrangler Technical Forum 18 03-05-2015 02:49 PM
Removing pocket-style fender flares replacing with factory flares domano 68 TJ Wrangler Technical Forum 18 04-09-2010 06:17 PM
Fender Flare Extensions for keeping grim off rear fender flares? FrankGG TJ Wrangler Technical Forum 7 12-05-2007 09:29 AM
Suggestions for cutting the rubber fender flares ? xaran YJ Wrangler Technical Forum 11 06-06-2007 03:04 PM
cutting fender flares cmoore TJ Wrangler Technical Forum 5 07-21-2003 11:49 AM
