Cutting body lift spacers ? How long are 1 inch body lift bolts ? - JeepForum.com
post #1 of 14 Old 01-23-2011, 07:24 PM Thread Starter
MAYNARDZ71
Ok i have a 97 TJ with a 3 inch body and i just ordered a 4 inch suspension lift. I want to cut the 3 inch body spacers in half to 1.5 but i dont know how long of bolts to get ? Also what all do i need to get with this 4 inch lift http://cgi.ebay.com/ebaymotors/1997-...item20b6ae8166 ? brake lines ? SYE ? or can i get away with out any of them.
MAYNARDZ71 is offline
post #2 of 14 Old 01-23-2011, 07:26 PM
jeepinmichguy_
Get a bolt an inch and a half smaller than you have in there now.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #3 of 14 Old 10-29-2012, 01:25 PM
FirstJeep05
Did it work?
Hey I was thinking about doing the exact same thing. I have a 3" body lift and am planning on getting a 4" pro comp SL. But 7" is just too much Did ya end up cutting the spacers? What did ya use to cut it? And how long where the screws ya ended up getting? Thanks for helping
FirstJeep05 is offline
post #4 of 14 Old 10-29-2012, 02:10 PM
zboss86
I did the same with my 2" lift. Just pull out the bolts and measure them... If you cut an inch off, get an inch shorter bolt. There's only 2 or 3 different lengths in the group.
zboss86 is offline
post #5 of 14 Old 10-29-2012, 02:16 PM
Cuder
Take them to a machine shop, shouldn't cost much, maybe a 12 pack.
My Build Thread:
Cuder is offline
post #6 of 14 Old 11-05-2012, 02:41 PM
FirstJeep05
I noticed you're also from Texas. Would you by chance be from Houston? And when you say machine shop what do you mean by that. Can you give me an example? Sorry I'm sorta new to all this
post #7 of 14 Old 11-05-2012, 11:06 PM
Cuder
I'm from DFW. Google "Houston machine shop" and take the body lift to your nearest one they should'nt charge much to cut them down.
My Build Thread:
Cuder is offline
post #8 of 14 Old 11-06-2012, 04:07 AM
rda616
Stay far, far away from procomp lifts! Procomp lifts are the bottom of the barrel.
rda616 is offline
post #9 of 14 Old 11-06-2012, 08:27 AM
88hatchy
They're no worse than Zone lifts.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #10 of 14 Old 11-06-2012, 09:17 AM
rda616
They absolutely are. At least zone lifts have a better shock offered with their kit and are made in the USA.
rda616 is offline
post #11 of 14 Old 11-10-2012, 02:45 PM
FirstJeep05
Well my firmd has a pro comp lift and he has nothing but good things to say about them. The main reason I'm inking about pro comp is that I found a shop that sells pro comp lifts and would sell it and install it for me for $1000. And so far that's the cheapest if seen it. Before lookin at pro comp I looked at BDS. Are they any good? I like the lifetime warrenty
post #12 of 14 Old 11-10-2012, 03:31 PM
rda616
Bds springs are some of the best you can buy. I have owned a procomp lift and from experience I can tell you there is no comparison in quality to what I have now, which I am still have a lot to improving upon. Procomp control arms are crap and can damage your brackets. They come with a drop pitman arm that shouldn't be used unless you want bump steer. Their shocks suck. I don't have anything good to say about them other then their springs aren't bad.
rda616 is offline
post #13 of 14 Old 11-12-2012, 10:00 AM
joe_jeep
bds or zone are good quality with a great warranty.
avoid procomp and rough country.
look into an sye and cv drive shaft. your gonna need it.
u can do control arms later when funds allow.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #14 of 14 Old 11-12-2012, 11:33 AM
Cuder
But you need upper rear adjustable control arms if you install a SYE, the rear pinion has to be on the same slope as the rear driveshaft.
My Build Thread:
Cuder is offline
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
Cutting 3 inch body lift down smithins TJ Wrangler Technical Forum 7 08-04-2009 08:35 PM
Cutting down a body lift. only_in_a_yj YJ Wrangler Technical Forum 5 01-07-2009 06:14 AM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Cutting down a body lift superdave624 TJ Wrangler Technical Forum 12 08-08-2008 02:49 PM
