Quantcast Cut Exhaust Pipe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cut Exhaust Pipe
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 05-19-2007, 11:48 AM   #1
Anti-bling
Cut Exhaust Pipe
Has anyone cut some of the end pipe off thier stock exhaust after a BL? It and the gas tank skid look silly. Pictures and suggestions would be great!
[SIZE="4"]'04 Wrangler Sport: Khaki, D30/D44, 2.25" BB, JKS 1.25" BL, OME Coils, Fabtech style front bumper, Herculined tub, Hi-Lift, Jerry Can, HUNSAKER ENVY seats, Flowmaster 40, CAI, Performance TB, 33x12.5's, Defender basket with SRC soft top rack, Lite Dot, CJ Tailgate, Rear Stinger. [/SIZE]
Anti-bling is offline   Reply With Quote
Old 05-19-2007, 01:03 PM   #2
Anti-bling
Heres a pic to give an idea...im thinking about cutting it right after it bends down behind the rear axle. Pic-
Old 05-19-2007, 10:08 PM   #3
CB3
I cut the last 3" or so off my Cherokee XJ because it would sometimes hangup or drag off-road during high departure angle situations. Cutting it off worked great.
I intend to do that with my LJ now, except do better than last time. Instead of just cutting it off, I'm going to have a muffler shop cut out a 3" section, then move forward the downward bend part. That way I still have the downward bend, which keeps exhaust, fumes, and associated rust issues away from the underside of body, but I can have better clearance.
CB3 is offline   Reply With Quote
Old 05-20-2007, 12:04 PM   #4
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
mine's dumped right after the Cat. It was dumped right after the axle where it goes up and over the axle because I bent the pipe off in the back on a rock. It's dumped after the cat right now because of my Clayton Long arm.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is online now   Reply With Quote
Glock Forum
