Customized D30 enforcement with pix - JeepForum.com
post #1 of 35 Old 03-22-2007, 02:53 PM Thread Starter
MeGAMoE
Hello guys,
i've made today an enforcement plate to hold my front D30 from being bent with lots of jumps we do in our kind of offroading which is dunes bashing. plz tell me your opinions. i''ve welded it to 3 places on the diff.
MeGAMoE is offline
post #2 of 35 Old 03-22-2007, 03:02 PM
McLovin
I like it alot. My housing is bent from my dune jumping. I have a HP30 I am setting up now. You were smart to truss it from the bottom, top only mounted ones will still eventually bend.
McLovin is offline
post #3 of 35 Old 03-22-2007, 03:33 PM
fish4life
you welded it to the axle housing ???
how exactly did you do that ..... welding to cast iron is pretty tricky. It requires lots of constant heat etc etc.
Please tell me you had the axle disassembled before you heated up the housing .... otherwise you can kiss all your bearings goodbye.
fish4life is offline
post #4 of 35 Old 03-22-2007, 03:35 PM Thread Starter
MeGAMoE
i did dont worry :mrgreen:
MeGAMoE is offline
post #5 of 35 Old 03-22-2007, 03:38 PM
yellowismellow
Custom User Title
yellowismellow's Avatar
not to hijack but i have a cracked a control arm mount at the front axle of my tj. does this mean i cant just weld it back in place?
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #6 of 35 Old 03-22-2007, 03:46 PM Thread Starter
MeGAMoE
yes you can, my friend also had a swaybar cracked bracket and he welded it back
MeGAMoE is offline
post #7 of 35 Old 03-22-2007, 03:48 PM
yellowismellow
Custom User Title
i dont have to dissasemble the axle?
2006 TJ Sport
post #8 of 35 Old 03-22-2007, 03:56 PM
fish4life
i think you could get away without disassembling the axle .... as the mount isn't cast iron, and is a few inches from the housing itself ..... I don't think there'll be enough heat transfered to the housing to worry .....
but DON"T take my word for it .... consult with others first
post #9 of 35 Old 03-22-2007, 04:13 PM
Stu Olson
Stu Olson's Avatar
Lost some ground clearance for sure.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #10 of 35 Old 03-22-2007, 04:21 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i was thinking same thing,
RnEmOvr is offline
post #11 of 35 Old 03-22-2007, 04:37 PM
jeep_chinto
was thinking the same thing but if ur playing in sand not much to have to worry about gettn tied up on rocks / mud..
nice lookn job i probably would have designed the lower tres not to take up the ground clearance but then again i play on rocks n mud
jeep_chinto is offline
post #12 of 35 Old 03-22-2007, 04:40 PM
Tacoma750
strong yes....But your ground clearance just went out the door. Nice work though
Tacoma750 is offline
post #13 of 35 Old 03-22-2007, 05:19 PM
fish4life
he lost like an inch clearance ?? you can regain that by inflating your tires
that ain't a big deal at all, compared to the protection gained.
I dont wheel in sand, but i doubt it's like getting hung up on a tree stump or rock
post #14 of 35 Old 03-22-2007, 05:23 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I guess the concept of an axle's overall footprint escapes you?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #15 of 35 Old 03-22-2007, 05:25 PM
fish4life
I guess the concept of a destroyed axle from jumping around escapes YOU ?
anyone ever customized a skid plate to go belly up tranzamwayno YJ Wrangler Technical Forum 7 04-01-2009 10:01 AM
Customized Stock Bumper flyinbrad YJ Wrangler Technical Forum 14 12-17-2008 09:57 AM
Customized Features? LHS-Cowboy JK Wrangler Technical Forum 7 04-15-2008 06:49 AM
Customized Roof Racks???? BigMac869 YJ Wrangler Technical Forum 16 03-02-2007 03:36 PM
Any Cali Law Enforcement on this forum? I have a Q ballardsj YJ Wrangler Technical Forum 2 07-04-2006 10:37 PM
