Custom suspension - JeepForum.com
post #1 of 8 Old 01-19-2011, 02:10 AM Thread Starter
Amerj
Custom suspension
Hey everyone, I'm new to the forum so bear with me. I got a 03 jeep tj sport a while back and am starting to get ready to lift it. These are not as simple as the old chevy trucks to lift. So my goal is to keep the jeep low maybe 3" of lift . Has anybody bought different lift components from different companies and put them on their jeep. I was considering the AEV 3" springs with the currie/ rokmen control arms, currie antirock, track bars any one that can reccomend a good company would be great,bilstein shocks. Is that what makes the lift or is there anything missed? But anyways would that work?
I'm trying to do it right the first time.
Amerj is offline
post #2 of 8 Old 01-19-2011, 02:23 AM
saddis
2014 JK Wrangler
You picked very good springs, shocks and control arms for a first lift attempt. Trackbars for a 3" lift are not a have to, in the front anyway. Some people might disagree, but the front tracbar holds up good for a 2.5 to a 3" lift. It also has great clearance for the front dif if any aftermarket cover is added. For the rear tracbar a good option would be currie or JKS. Just remember to correct the bumpstops so you won't have any tire rubbing on the fenders. What tire size are you planning on running?
Steven
saddis is offline
post #3 of 8 Old 01-19-2011, 05:06 AM
Sundowner
Understandable.
All of the companies you've mentioned are reputable, but I'd say the track bars are a must-have, personally. You're also going to want to think about what 3" of lift will do to your driveline angles.
Sundowner is offline
post #4 of 8 Old 01-19-2011, 10:43 AM Thread Starter
Amerj
Alright sounds like I'm on the right track. I'm gonna run 33s for now so I have time to build for 35s properly (is drivetrain) . I'm not sure what you mean about the bumpstops. Can you explain?
Like I said new to the forum . Gotta learn sometime
Amerj is offline
post #5 of 8 Old 01-19-2011, 10:48 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Bump stops are rubber/poly "stops" that limit the axle up travel.
IE, when you jump off of something and "bottom out" the bump stops are what stop the axle from crashing through the frame.
(Note that some people sue their shocks for this but it is not recommended as it can/will damage the shocks).
By installing longer bump stops you prevent the axle from traveling to far upwards thus preventing larger tires from getting into the body work.
So, if/when you install larger tires, even if you have a lift, you still need to limit the up travel. Otherwise your axle could end up tucked up into the fender and with a larger tire ... bad things can happen.
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #6 of 8 Old 01-19-2011, 11:35 AM Thread Starter
Amerj
Okay great. That makes sense. I will have to add that to my to-do list. I will post pictures after it's all installed.
Amerj is offline
post #7 of 8 Old 01-19-2011, 12:04 PM
ytowntj
For everything you mentioned buying other than the AEV springs (which I hear are awesome) I would contact Gerald at Savvy offroad for purchasing. He should be a bit cheaper (and tons more knowledgeable) than almost any other vendor out there. If you give him a call he can probably talk to you about some of the products you mentioned and how they will work together.
If it were me and I had the $$$ I would build to you general specs like this:
33 Bfg KM2s or Goodyear MTR kevlars for a MT, for AT go BFG AT or Duratrac
3" AEV springs
Bilstein 5100s
1" BodyLift /1" Motor mount lift OR Advanced Adapters SYE and Tom woods DC shaft
Currie or Rokmen arms
The Currie front upper axle end joints - If you can weld. I hear the greatly increase handling on road...
Currie antirock up front, stock swaybar in the rear
Currie track bar (talk to Gerald though to make sure it wont contact the front diff for only 3" of lift)
ZJ tie rod
Currie bumpstop kit. I have 2inch bumpstops up front and 1.25" in the rear for my 3" lift, but yours may be different
If you go the cheaper MML/BL route, you can do the SYE and driveshaft down the road and do a flat skid/tummy tuck. That would give you the belly clearance of 35s or bigger with only 33" tires.
When you go to 35s you need axle upgrades, steering upgrades, and brake upgrades. None of which are cheap.
The setup you outlined will be very capable. If you dont drive in the snow everyday, I would recommend Getting a front lunchbox locker. They do wonders offroad. I believe you can get an Aussie Locker for 249$ shipped currently from Northridge.
ytowntj is offline
post #8 of 8 Old 01-19-2011, 03:36 PM Thread Starter
Amerj
Okay thanks for the heads up. I will be calling him shortly. Thanks for the outline that is a huge help.It's easy to get lost trying to piece a kit together. Now all I have to do is buy em and put em on.
Amerj is offline
antirock , lift , low , suspension
Custom Suspension Pan Hard Bar orrious TJ Wrangler Technical Forum 0 10-06-2010 10:53 PM
custom suspension tips dusterjeeps TJ Wrangler Technical Forum 21 09-16-2010 01:26 PM
TNT custom long arm suspension dls965 TJ Wrangler Technical Forum 8 06-03-2010 09:10 AM
custom suspension vs. aftermarket jackadf YJ Wrangler Technical Forum 19 03-16-2008 11:37 AM
Custom Suspension Daylan TJ Wrangler Technical Forum 4 11-20-2006 12:33 PM
