-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Custom storage enclosure (http://www.jeepforum.com/forum/f9/custom-storage-enclosure-1734210/)
05LJTampa 10-28-2013 09:14 PM
4 Attachment(s)
So I need something bigger than my current instatrunk in my LJ since I now have that wasted 10-12" between it and my back seat. Having the deeper storage would be great to lock up all my vests, wetsuits, leashes, tools & winch accessories. So I decided to incorporate a downfiring sub enclosure into it as well going off some ideas on this forum Im come across but were geared towards regular tjs.
Think this will work? Ive been planning it out off and on the last week and self taught myself the design software.
Pentara 10-28-2013 09:40 PM
Do you actually have a sub in your trunk for that separated area on the right? Also, it might be nice if the final version wasn't flush flat at the top but had a slight lip around the edges to prevent things from sliding off the top. Another thing you can consider is putting a hinge on the end so the top can be lifted up, and then with that center divider there you can easily insert a locking mechanism to prevent it being raised without access to the inside.
Just a few thoughts, but great effort.
05LJTampa 10-28-2013 09:49 PM
Yeah on the right (rear of the large storage area would be a downfiring sub enclosure with some storage in front of the enclosure facing the tailgate) I put it flush at the top bc I dont ever see putting anything up there bc my top is down for 10months or so and would think adding a hinge top would just rattle too much bc of the bass. I really would access it from the tailgate since I have a swing away carrier and the spare tire sits so high. Great ideas and thats why im reaching out to you all to tweak my design
SOWEGA TJ 10-28-2013 10:01 PM
i have a tj but plan on removing the rear seat...do you have the measurements of the top piece
Pentara 10-28-2013 10:09 PM
If you always have your top off then any consideration on adding weather stripping or some sort of seal to prevent water / airflow / dirt? Is that even a concern for you?
Also are you thinking of having this made out of wood, steel or plastic?
If you'll be making this yourself the one thing I strongly recommend is to make a template for each piece. (An item the right size with all the holes in the right place, like a stencil almost) This way if you ever want to re-create it (Maybe start making and selling them to other owners ;) you'll have an easy time. I once tried to make a bookshelf and didn't consider templates, so each piece of the bookshelf was a 1 off custom and suffice to say, they didn't fit together very well. :p
05LJTampa 10-28-2013 10:32 PM
Yeah was going to take the weatherstripping from the instatrunk that i never installed and use that fill the gap btwn the enclosure and the tailgate.
I was going to use 3/4" mdf for at least the sub enclosure portion. I think the first one I do i'll bedline the entire storage area if I use mdf and see how that holds up. If it doesnt, then I'll fabricate it out of steel or fiberglass although Ive never used fiberglass before but may be worth trying. I live in FL so the top is really only up in july & august when its raining.
05LJTampa 10-28-2013 10:34 PM
Its on my computer and Im on my phone now, but its roughly 35" wide and this is 22" deep.
I'm sure glad I bought an LJ instead of the TJ I was looking at bc I can keep my backseat in with this. Never know when I might stumble on 3single ladies wanting to ride in the jeep:)
SOWEGA TJ 10-28-2013 10:45 PM
10-4. 2 can fit in the passenger seat and 1 on my lap :D
05LJTampa 11-12-2013 09:10 AM
6 Attachment(s)
UPDATE:
Heres the finished product. Turned out nice, had to make a few adjustments of real world jeep fitting vs my computer based design.
Lockable storage area now bigger than the instatrunk, for my tools, computer, wetsuits, vests and anything else really.
Holy smokes, anyone who ever says a jeep cant have bass when the top is down or doors off is full of it. Drove it yesterday 65mph no top or doors and even seat folded forward. Downfiring makes a huge difference. Running a single JL10w3
ob269 11-12-2013 09:26 AM
The 10w3 makes a huge difference too lol
Sweet looking box though..
The time now is 04:28 PM.
