custom roll cage idea - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > custom roll cage idea
Want to be able to SEE? DOT Approved Headlights for under We have FLASHLIGHTS! Great for your Emergency bag!Flowmaster Overstock: Special Holiday Pricing!!!!
Unread 07-06-2009, 09:45 PM   #1
yellowismellow
rubber duck sicko!
yellowismellow's Avatar
a buddy of mine is swapping his roll cage for an aftermarket one, and im going to be taking his cage. im also going to learn to weld. once i get decent at welding, i plan on cutting his stock cage up and using the pieces to reinforce my stock cage. is this worth it? i plan on adding a rear spreader, 45's running from the center hoop to the rear corners, and maybe sleeving the stock windshield-center hoop bars.
should i even tackle this? or save for a real cage?
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline   Reply With Quote Quick reply to this message
Unread 07-06-2009, 09:50 PM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
no its not worth it. just buy the right stuff - 1.75x.120 DOM. the stock cage is a reasonable place to build from, but I wouldn't purposely cut up a stock cage to use as reinforcement - theres to many holes in it (padding mounts, seat belt mounts, soft top brackets, etc)
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2009, 10:45 PM   #3
Jeepguy1977
And don't forget that the B-pillar hoop is multi-piece besides.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote Quick reply to this message
Unread 07-07-2009, 09:05 PM   #4
yellowismellow
rubber duck sicko!
bump for more opinions.
2006 TJ Sport
Unread 07-07-2009, 09:10 PM   #5
little_Jeep
Do it right, or don't do it at all. Forget your idea. Also, welding a cage is NOT something that a newbie welder has any business messing with.
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 07-07-2009, 09:39 PM   #6
Dogman
Don't even talk about a cage until you have learned to weld and have several projects under your belt. Keep reading about cage design, there is a good thread in the Fabrication shop "stickies".
Welding is a lot of fun, but it's also a lot of practice. I have been doing it for a few years now and I'm just to the point where I would even consider doing a cage (which is coming soon).
Personally, I would keep saving and go with something like the AtoZ sport cage additions. I have a buddy with a bender, so I'll probably be making my own based off of that.
Good luck
Dogman is offline   Reply With Quote Quick reply to this message
Unread 07-07-2009, 09:51 PM   #7
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depends on the year. I know at least in 03 they welded them together and that's a pretty high strength way to do it. Or at least it's a very acceptable method for truck frames, so it should be just fine for a B pillar.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 07-07-2009, 10:04 PM   #8
Jeepguy1977
I haven't seen any welds on mine so far. Just seemed strange to me. But I would think either way, it wouldn't be a terribly good to build a cage by scavenging parts from a second stock roll bar.
Unread 07-07-2009, 10:31 PM   #9
Unlimited04
on my 04, the B-pillar's slip fit joints were only welded on the top, maybe 1.25-1.5 inch long on each side. One weld was absolute crap, a fair amount of porosity and a HUGE bugger hanging off - literally a razor sharp wire sticking up like 1/2" - you could cut your finger half off if you grabbed the bar, no kidding. We ground that crap out and put two passes all the way around on each joint.
