Quantcast Custom Reverse Lights? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Custom Reverse Lights?
Old 12-14-2007, 04:59 AM   #1
TJamz
TJamz's Avatar
Any pics on custom back up lights? This is my next project. I was going to go w/ Walmart/Canadian tire specials since there only reverse lights and cheap.
Something small, out of the way, low profile. Any tips?
TJamz is offline   Reply With Quote
Old 12-14-2007, 05:22 AM   #2
Oman Jeep
Make sure it's a fog light.
I've got PIAA's with a 90 degree beam pattern. That means they light up the area 45 degrees to the left and 45 degrees to the right. When you're reversing, you'll be going slow and possibly doing a lot of steering - so a spot beam is useless.
I love my PIAA's because it's a nice smooth beam pattern and VERY bright out of a very small light, but if you want to go cheap, just make sure it's a fog beam.
I wired mine up independently of the reverse lights so I can turn them on as a work light if I wan to, and they don't come on in the city.
Oman Jeep is offline   Reply With Quote
Old 12-14-2007, 06:06 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
No pics,but I'm mounting some bright back up lights inside my Warn bumper behind the "W" cut out on each end
TheBoogieman is offline   Reply With Quote
Old 12-14-2007, 06:49 AM   #4
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
I used walmart fogs and wired them to a new switch next to the rear wiper and defrost swithces. I got a new OEM toggle for $25 at the stealership.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 12-14-2007, 08:16 AM   #5
TheBoogieman
Demonic Jeep Freak!
Was that bumper accessory included with them?
Old 12-14-2007, 08:39 AM   #6
skyjacked94xj
Matches the jeep
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline   Reply With Quote
Old 12-14-2007, 08:56 AM   #7
dogbluedrummer
Trust me....
Let's just say it took a long time to add the lights, but I had a lot of fun!
My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892
Old 12-14-2007, 09:08 AM   #8
motobob13
Can the fog lights (like 55W) be wired directly to the factory backup light circuit or does a relay need to be included? I'm also a fan of that model "bumper accessory".....
motobob13 is offline   Reply With Quote
Old 12-14-2007, 09:39 AM   #9
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
not mine but if you get slim ones you can mount them like these.
I had KC lights on the rear of mine but I took them off because i didn't have a good mounting system.
I'm going to weld a tab on the rear bumper in January and drill a hole to mount them again.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 12-14-2007, 09:56 AM   #10
erickpl
20.00 specials from O'Reilly's, mounted on the tire carrier.
Works on the reverse circuit AND from a switch on the dash...
Far right switch
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Old 12-14-2007, 10:10 AM   #11
TheBoogieman
Demonic Jeep Freak!
I'm wiring mine directly into the backup light wires on the factory lights.
Old 12-14-2007, 10:12 AM   #12
heezy101
'98 TJ, Rough Country Long Arms, Curry HD steering with Redneck Ram Hydro assist, RE 4.5" Springs, Bilstein 5100's, 15x8 Procomp 1079, 35x12.50 BFG KM2's, LOD Signature series rear bumper and tire carrier with lights, Super 35, 4.56's, Detroit TruTrack front, ARB rear, Viair Heavy Duty OBA
heezy101 is offline   Reply With Quote
Old 12-14-2007, 10:18 AM   #13
Crashnburn80
I would use a relay if your planning on keeping the factory lights opperational.
The factoy lights are not 55w, and if they were you would be doubling the load on that circuit by adding 2 more 55w lights, since they are likely less you will be more than doubling the load, which is asking to blow fuses at best.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 12-14-2007, 11:30 AM   #14
19OlllllllO41
Jeep Addict
19OlllllllO41's Avatar
X2, I would not wire them directly into the factory reverse lights, too much load for the stock wiring. You would be asking for trouble as Crashnburn80 said.
'93 YJ (Under Construction)
Previous Jeeps:
'83 CJ7
'92 YJ
'00 XJ
'99 TJ
'05 TJ Rubicon
19OlllllllO41 is offline   Reply With Quote
Old 12-14-2007, 01:35 PM   #15
TheBoogieman
Demonic Jeep Freak!
thanks a bunch for that info but I was just going for the effect of the lights shining through the Warn "W".I was just going to wire small lights(not 55w),so do you still think the relay is the way to go?Thanks.
Glock Forum
