Custom Hitch Mounted Tray for a TJ - JeepForum.com
post #1 of 14 Old 07-18-2011, 01:10 PM Thread Starter
GotLime
Here was my dilemna:
I have a 2004 TJ.
I have a girlfriend
I have 2 kids
We like to go wheeling
We'd like to go camping
We like to take the Jeep to the boat
With the back seat in, I'd have to ask other folks to carry my cooler on the trail. No storage!! That little bit of space behind the rear seat is almost useless. The lack of storage limited what I could and would do with the Jeep.
I had one of those trays that slides in the receiver. With the spare tire hanging down, it limited what you could put on the tray and I didn't like how low to the ground it was.
My buddy Chris is a pretty talented guy. He has a full time job, but it trying to get his company, Blue Note Fab, off the ground. We were at his house Saturday playing with the Jeeps and I asked if he could make me an extension that would take the tray out past the spare and make the tray more usable. "Sure, come by tomorrow morning, pick me up and we'll take it over to my shop."
So I pick him up, we get some Subway for breakfast and off to the shop we go. It was a long day, but so worth it. I'm in the doghouse with the GF, but this tray is so useful now. He learned a thing or two that he might do different next time. Nothing major, just cuttting some holes in the tube to run wires and little stuff like that. I can't wait to sue this thing!
On to the pics.
Disclaimer: In some shots, it may appear tubes are not square. They aren't. My Jeep is not square so we made the tray fit the Jeep instead of making it squarwe. And I've never noticed it before, but the Warn rear tire carrier does not center the spare. It is to the left. I'm not sure why.
Who knew we'd use jackstands? Mocking it up.
Chris replaced everything on the tray except the frame and the mesh floor. This is the new center support.
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
GotLime is offline
post #2 of 14 Old 07-18-2011, 01:11 PM Thread Starter
GotLime
Chris even gave me a quick lesson and allowed me to weld a little bit. To you guys that know how to do it, I'm sure it doesn't seem exciting, but it was fun for me!!
We struggled with what to do with the plate. It would be covered if there was anything on the tray. Chris came up with an idea to mount the plate on the tray. It can easliy be moved from the mount in the spare to the tray now. With an extension to the wiring, the license plate light and integrated 3rd brake light will also work!
Chris added these supports under the mesh to help keep the tray rigid and support the weight of the cargo.
Shot from underneath:
Chris fabricated this piece that goes AROUND the receiver. It can be used to attach straps to the tray or chains if I was towing a trailer. It can be removed when not in use. Super cool!
Chris fabricated these tabs and welded them to the tray. If I want to use a ratchet strap to further secure the tray to the Jeep, I can attach them here and to the piece he made that is attached to the receiver (see above). These look really cool.
The almost finished project. We realized that if the tray was being used, the taillights would be blocked. So I'm going to buy some trailer lights and mount them to the tray. Chris drilled holes in the tube so we can run the wiring internally. We'll have it ste up so I can move the plate and connect the lights for it and the tail lights very quickly and easily when using the tray and it will look very clean.
Build thread:
GotLime is offline
post #3 of 14 Old 07-18-2011, 01:33 PM
Xlr8n
1967 JK Wrangler
Nice fab. I need the same for my tray. I was going to give this a whirl: http://www.harborfreight.com/hitch-e...tep-97685.html
I figured if I supported the load with a couple ratchet straps up to the spare carrier it should hold up fine for simple hauling, but your design gets a bunch more clearance for offroad use.
Xlr8n is offline
post #4 of 14 Old 07-18-2011, 02:03 PM Thread Starter
GotLime
We measured clearnace. 45 without the tray. 25 with the tray and a "flat" extender. 35 the way it sits now. The idea is not really to wheel it with this on. Just to get to the campsite, unload, remove it and wheel. But I think you could wheel MOST places around here with it in place if you wanted/needed to though. .
Build thread:
GotLime is offline
post #5 of 14 Old 07-21-2011, 01:35 PM Thread Starter
GotLime
Lights still need to be wired up. I'd like to find a set of stock taillights, but these will do for now:
Build thread:
GotLime is offline
post #6 of 14 Old 07-21-2011, 02:16 PM
Ross
I had a cross bar and receiver welded between my roll bars in the rear and can slide in a hitch tray up there. Only down side is you cannot zip up the window when it is installed, but it is out of the way.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #7 of 14 Old 07-21-2011, 03:12 PM
mattlock1983
mattlock1983's Avatar
looks good.
i have a question about the departure angle though:
with welding skills like that, why didnt you make this into a spare tire rack? (i.e. mounted over the spare tire)
edit: i just saw this:
Originally Posted by GotLime View Post
The idea is not really to wheel it with this on. Just to get to the campsite, unload, remove it and wheel..
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #8 of 14 Old 07-21-2011, 04:05 PM
Mike_Motorbike
http://www.harborfreight.com/catalog...cargo+carrier+
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #9 of 14 Old 07-21-2011, 07:32 PM
bfewkwa
I'm interested in a better shot of the piece around the receiver for safety chains/straps. I have the same Warn bumper/tire carrier and have been looking for a simple solution like that. You say it is removable?
bfewkwa is offline
post #10 of 14 Old 07-21-2011, 08:12 PM
EPrest90
I had the same dilemma...so I decided that i'm going to mount a hitch receiver up on the front bumper. it'll look goofy, sure, but the exhaust fumes can't bother the luggage, and it wouldn't be used too often
EPrest90 is offline
post #11 of 14 Old 07-21-2011, 08:59 PM
Broncbuster
I basically did the same thing. I did drill a hole in the bottom of the receiver and weld a nut on it. I use a bolt to tighten up against the drawbar on the carrier to keep it level and from being wobbly.
Broncbuster is offline
post #12 of 14 Old 07-22-2011, 12:40 PM Thread Starter
GotLime
Originally Posted by mattlock1983 View Post
looks good.
You got it man. It started out as just making an extension for the receiver. Then Chris was like "We can raise it up some. We should add some supoports. We should add soem tim downs. What about your plate?" and here we are. We did come up with some great ideas for a spare tire rack that I hope we can work on soon. I see this as something smaller I can leave on all the time. Throw a boat bag and a small cooler up there and go. And I could use it it conjunction with the3 current rack.
They all have their pros and cons. This rack is lower so it's easy to put stuff up on and you could use it as a workbench or table if you wanted to. But it blocks the plate/lights, tyou can't open the tailgate and it's not practical to elave it on all the time. The spare tire rack you could elave on all the time, but it may not be easy to lift heavy objects up there and it could block what little rearward visibility I have.
I think there is a place for both though. Choices are good.
Build thread:
GotLime is offline
post #13 of 14 Old 07-22-2011, 12:44 PM Thread Starter
GotLime
I'll see if I can take a better pic. Yes, it is removable. It is open at the bottom and slides down over the receiver.
If you're really interested, send me an email at chrisahughesatgmaildotcom and I'll see what he'd charge for one.
It's all custom cut, ground, welded, etc so I have no idea what he'd charge.
Build thread:
GotLime is offline
post #14 of 14 Old 07-22-2011, 12:47 PM Thread Starter
GotLime
I've got enough stuff sticking out the front now:
Build thread:
GotLime is offline
Front mounted hitch zamball JK Wrangler Technical Forum 23 07-11-2011 03:38 PM
Receiver hitch mounted winch FatBuoy JK Wrangler Technical Forum 14 10-28-2010 05:50 PM
front mounted hitch whyknot JK Wrangler Technical Forum 4 03-17-2008 03:24 PM
Hitch Mounted Tire Carrier RLD831 TJ Wrangler Technical Forum 16 06-14-2007 06:13 AM
Hitch mounted winch m00n TJ Wrangler Technical Forum 3 07-05-2004 11:30 PM
