Custom gauges MIL(check Engine) light help - JeepForum.com
post #1 of 1 Old 07-26-2012, 01:40 PM Thread Starter
desertrhino
ok Friends I have been banging my head on this. I replaced my instrument cluster on my 2002 TJ with auto meter gauges, which is great but the state requires me to have an idiot light or check engine light in order to [pass the visual part of the emissions test never mind i have a scan guage II connected. So i would like to connect an led light so the morons can see it go on and off. I am at a loss I have the pin out diagram for the instrument cluster plugs it has the airbag light, the brake but no MIL(check engine) it does have one labeled pci bus not sure what that does. Pin out diagram below.Any Ideas appreciated. Thanks
desertrhino is offline
check engine light , custom wire harness , gauge cluster
Check Engine Light/Check Gauges Light eastwood1972 TJ Wrangler Technical Forum 3 11-16-2010 06:06 PM
engine over heating with check gauges light calrain07 TJ Wrangler Technical Forum 6 04-09-2010 07:44 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 09:02 AM
Check Gauges light Jeepinoldman TJ Wrangler Technical Forum 5 11-10-2007 05:35 PM
