Custom Front and Rear bumpers, Check them out!!
#31 | |
All I see are x's.
#32 |
Cut to Fit-Paint to Match
Those things look like poo-poo. PM me for an address that you can send them to, where they will be properly disposed of.
![]() Kidding aside, very nice work, man. I think those look great.
We save dogs: http://www.secondchanceshepherds.org/ |
#33 |
OK, I see them now. They are super nice for sure. Here is my front:
V-8 wrangler: http://www.jeepforum.com/forum/f9/v-8-unlimited-build-562450/ |
#34 |
I give it 2 thumbs up. I really like that rear bumper design. That is slick. For the front I prefer the shorty bumpers, but that is a nice design.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein http://www.venemousduckracing.com |
#35 |
how heavy are they? is the plate 3/16 or 1/4?
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#36 |
Looks good...
Front tube guard should be round tube instead of box sections though.... and in the rear I would change your tire carrier mount to include an upper plate on the hinge bolt. It's the way ARB does it and I'm sure it's a major contributing factor to how solid the tire mount is. |
#37 | ||
The front is all of 3/16 but the winch plate it 3/8. Quote:
Here is the design I am thinking of now for the Tire Carrier. ![]()
l _____ /l ,[____], l---L –()lllllll()- ()_)-()_)--o-)_) TWS Designs |
#38 | |
make an X or H pattern, add gussets to the base and top where the forces will be concentrated here the FEA I did on mine: ![]() Notice the 1/4 plate gusset under the tire carrier 'hitch' and at the hinge.
#39 |
what forces did you use to test your design?
#40 |
i think this was 500lbs vertical force on the tire carrier 'hitch', all along that inside surface. I made the ID of the hinge an fixed constraint. I then looked for force on the gussets and weld areas, and a vertical deflection at the hinge location. I made a droop stop at my latch, and padded it with some 3/8" solid rubber, so that if the hinge is forced to flex due to weight, it will bottom out on the latch side, creating 2 points to dissipate forces, instead of all the force creating a torque on the hinge.
I also did a little FEA on getting rear-ended (or sitting the jeep on its rear), to see how much deflection I would see if somebody hit the spare tire. No pictures, but its not pretty at all....the tailgate is pretty much gone. This is why I drive with a long hitch sticking out past my spare. My spare is adjustable so I can put 2 gas cans on the carrier to...or suck the tire down if I don't want to carry so much junk around.
#41 |
I have not been very good at FEA if I send you the file could you run the test?
#42 |
if the complete set-up...front and rear could be bought and shipped for less than a grand i'd be in for the front and rear.
i personally think they are bad ***.i have the bestop high rock front and rear w/ approach rollers and would get rid of them both for your setup....i personally would not want a stinger...maybe a hoop over the winch mount but the big *** stingers are not my style. look's great..keep up the excellent work. |
#43 | |
Here's what the arm looks like on my favourite carrier: ![]() |
#44 |
Nice job. Those are some sweet bumpers for sure.
It's easier to go down a hill than up it but the view is much better at the top. -Henry Ward Beecher Current - '98 Black Z28 with some goodies Previous - '97 Gun Metal Blue TJ Northern Illinois Extreme Jeep Club www.ExtremeJeepClub.com |
#45 |
That is some awesome work. Fantastic job, man!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
