Custom door mounts - JeepForum.com
post #1 of 13 Old 04-17-2012, 10:05 PM Thread Starter
KenleyR
Custom door mounts
So I got tired of just leaning my doors up against the wall with a town under them and decided I'd figure out a safe cool way to store my doors and vinyl windows when they are not on my jeep (which 99.9% of the time they are off) So this is what I came up with.
Went to lowes and bought 4 of these:
Measure where I wanted them.... leveled them out... the whole 9 yards
Then I decided to drill in two small pieces of velcro under each arm for the vinyl windows for the side of the jeep.
So here is the left side all on the wall and the right side what it looks like empty
Minus on door:
Holding almost everything:
To top it off it even hold the rear vinyl window!
It holds everything and the Jeep still has room to sit inside the garage.
Will that's it for my thread, I hope you enjoyed and let me know what you did for your doors or if you like/dislike mine.
KenleyR is offline
post #2 of 13 Old 04-17-2012, 10:07 PM
Benderff
Benderff's Avatar
I like it. Hanging them like that makes me nervous.
Benderff is offline
post #3 of 13 Old 04-17-2012, 10:13 PM
SlackJaw
baby jeep
SlackJaw's Avatar
that is sweet dude
Should be no nervouse over hanging them...tied into studs, and at weight, should handle 3x weight.
That is a really nice setup, and about to "spring clean" my garage as well.
SlackJaw is offline
post #4 of 13 Old 04-17-2012, 10:16 PM
2jhanna
Although I also hang mine from the window frames, it has been stated here that this method is bad for the welds of the window frames to the door cracking.
jhanna
denton county, tx
2jhanna is online now
post #5 of 13 Old 04-17-2012, 10:17 PM Thread Starter
KenleyR
Well these mounts were rated to hold 50lbs on each, so with two of them it can hold 100lbs and the door is 56lbs so it's gooooood... Plus it's into concret and the tap cons will hold 75lbs each and there is 4 for each door. You could hang a Buick on those!!!!!
KenleyR is offline
post #6 of 13 Old 04-17-2012, 10:18 PM Thread Starter
KenleyR
Has they been proven? I thought it was more so a myth???
KenleyR is offline
post #7 of 13 Old 04-17-2012, 10:20 PM
Tylerzap
I like it.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #8 of 13 Old 04-17-2012, 10:25 PM Thread Starter
KenleyR
Have you seen or heard anyone who has had problems with it? I'm curious because if so I may grab another mount to support some on the weight from the bottom. But I just thought more so could have been from abuse to the door prior to them being hung by the window frame.
KenleyR is offline
post #9 of 13 Old 04-17-2012, 10:30 PM
SlackJaw
baby jeep
SlackJaw's Avatar
link?
SlackJaw is offline
post #10 of 13 Old 04-17-2012, 10:32 PM
2jhanna
I'm sure someone will chime in.
I have mine hanging from those large vinyl covered bicycle hooks that are screwed into the ceiling joists of my workshop. They get hung there at the start of spring and aren't disturbed until the end fall when I re-install them. I am careful when hanging and removing, so I don't worry too much. I figure they get more of a shock just being opened and shut during normal use.
jhanna
denton county, tx
post #11 of 13 Old 04-17-2012, 10:59 PM
jeepinjeffrey
I love the mount! ive been looking into the same thing, hope there isnt any problems from that holding spot
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #12 of 13 Old 04-18-2012, 01:15 AM
athos76
Over time the welds at the bottom of the window will start to crack. Hanging them by the window frame can speed that up. Throw a bracket under neath so the weight of the door is spread between both sets.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #13 of 13 Old 04-18-2012, 06:28 AM
cubalz
Nice job. I love good 'ol American ingenuity at work.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
custom , door , hanger , mount , storage
Any custom Jerry can mounts? 21Bravo TJ Wrangler Technical Forum 19 05-29-2013 03:02 PM
99 tj custom rear upper control arm mounts? Neurosis TJ Wrangler Technical Forum 6 04-30-2012 10:49 AM
DIY TJ Door Holders/Mounts 02ws666 TJ Wrangler Technical Forum 4 01-24-2012 07:00 AM
Let's see your custom fabbed axle end anti-sway bar link mounts. NotURMailman TJ Wrangler Technical Forum 4 12-09-2009 05:01 AM
door custom lock mechanism fix jeepwrnglr92 YJ Wrangler Technical Forum 12 01-17-2008 01:47 PM
