-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Custom door mounts (http://www.jeepforum.com/forum/f9/custom-door-mounts-1358157/)
KenleyR 04-17-2012 10:05 PM
Custom door mounts
So I got tired of just leaning my doors up against the wall with a town under them and decided I'd figure out a safe cool way to store my doors and vinyl windows when they are not on my jeep (which 99.9% of the time they are off) So this is what I came up with.
Went to lowes and bought 4 of these:
http://i18.photobucket.com/albums/b1...at112754PM.png
Measure where I wanted them.... leveled them out... the whole 9 yards
http://i18.photobucket.com/albums/b1...8/IMG_1535.jpg
Then I decided to drill in two small pieces of velcro under each arm for the vinyl windows for the side of the jeep.
http://i18.photobucket.com/albums/b1...8/IMG_1539.jpg
So here is the left side all on the wall and the right side what it looks like empty
http://i18.photobucket.com/albums/b1...8/IMG_1537.jpg
Minus on door:
http://i18.photobucket.com/albums/b1...8/IMG_1541.jpg
Holding almost everything:
http://i18.photobucket.com/albums/b1...8/IMG_1542.jpg
To top it off it even hold the rear vinyl window!
http://i18.photobucket.com/albums/b1...8/IMG_1543.jpg
It holds everything and the Jeep still has room to sit inside the garage.
http://i18.photobucket.com/albums/b1...8/IMG_1544.jpg
http://i18.photobucket.com/albums/b1...8/IMG_1545.jpg
Will that's it for my thread, I hope you enjoyed and let me know what you did for your doors or if you like/dislike mine.
http://i18.photobucket.com/albums/b1...8/4a490773.jpg
Benderff 04-17-2012 10:07 PM
I like it. Hanging them like that makes me nervous.
SlackJaw 04-17-2012 10:13 PM
that is sweet dude :thumbsup:
Should be no nervouse over hanging them...tied into studs, and at weight, should handle 3x weight.
That is a really nice setup, and about to "spring clean" my garage as well. :o
2jhanna 04-17-2012 10:16 PM
Although I also hang mine from the window frames, it has been stated here that this method is bad for the welds of the window frames to the door cracking.
KenleyR 04-17-2012 10:17 PM
Well these mounts were rated to hold 50lbs on each, so with two of them it can hold 100lbs and the door is 56lbs so it's gooooood... Plus it's into concret and the tap cons will hold 75lbs each and there is 4 for each door. You could hang a Buick on those!!!!!
KenleyR 04-17-2012 10:18 PM
Has they been proven? I thought it was more so a myth???
Tylerzap 04-17-2012 10:20 PM
I like it.
KenleyR 04-17-2012 10:25 PM
Have you seen or heard anyone who has had problems with it? I'm curious because if so I may grab another mount to support some on the weight from the bottom. But I just thought more so could have been from abuse to the door prior to them being hung by the window frame.
SlackJaw 04-17-2012 10:30 PM
link?
2jhanna 04-17-2012 10:32 PM
I'm sure someone will chime in.
I have mine hanging from those large vinyl covered bicycle hooks that are screwed into the ceiling joists of my workshop. They get hung there at the start of spring and aren't disturbed until the end fall when I re-install them. I am careful when hanging and removing, so I don't worry too much. I figure they get more of a shock just being opened and shut during normal use.
jeepinjeffrey 04-17-2012 10:59 PM
I love the mount! ive been looking into the same thing, hope there isnt any problems from that holding spot
athos76 04-18-2012 01:15 AM
Over time the welds at the bottom of the window will start to crack. Hanging them by the window frame can speed that up. Throw a bracket under neath so the weight of the door is spread between both sets.
cubalz 04-18-2012 06:28 AM
Nice job. I love good 'ol American ingenuity at work.
The time now is 10:08 PM.
