currie or teraflex rear shock relocation brackets?
#1 | |
I am going to need relocation brackets when I adjust my pinion angle for my new cv driveshaft. Is there a benefit to either of these brackets or are they pretty much the same?
#2 |
Master of Reality
I have the Currie ones but they are probably about the same.
Just make sure you check your suspension travel and verify that the shock is not bottoming out at full compression, i.e. you do not want the shock to act as a bumpstop. With the added leverage of the extenders, you are more likely to rip the shock mount brackets off the axle. The shocks are not meant to be bumpstops, and I often hear of people ripping the brackets off the frame and blaming it on the extensions. The shocks by themselves do not put that much force on the brackets, but allowing them to bottom out will put way more force on the brackets than they are able to withstand. Bottom line: If your shocks bottom out before your bumpstops limit the uptravel of your axle, then you'd better adjust your bumpstops. Chuck
Chuck Grissom Black Jeep Society Member My Jeep Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas A. Edison |
#3 |
Curries products>Terra products.My 2 centavos.
Large vacuum leak sucking all the dead presidents out of my wallet. |
#4 |
I have an ome 2" lift, bpe's and 1 3/4 spacers... so right now my shocks are a little short so hopefully I should be good.
whats the best way to test if the shocks are bottoming before I get on the trail? |
#5 |
Do it right or not at all
![]() Join Date: Jan 2003
I wouldn't run either brand. Shock relocation brackets like that are bad news in that they increase the leverage against where the OE mount is welded to the axle tube enough so they can be torn off at the weld by trail obstacles. I believe you are much better off either inverting the shocks to give the needed clearance, or welding on new brackets that give more clearance.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#6 |
Tim Phoenix, AZ 2004 Wrangler Unlimited, 4.0L auto, 4" Teraflex lift, 33x12.50x15 Goodyear MT/R's on MT Classic II wheels, ARB's front and rear, 4.56 gears, York OBA, Milemarker E9000 Winch, Shrockworks Rocksliders, KOZ Offroad Rear Bumper, Skid Row Engine Skid, Bestop soft half doors, Raingler Pet Nets |
#7 |
yes I want to go with a weld on bracket eventually..... right now I just need a fast and economical solution for my dd so I can set my pinion angle without damaging my shocks.
#8 | |
Locked @ both ends
#9 | |
#10 | |
Inverting the shocks really doesn't fix the problem though. You will gain clearance at ride height and your shocks won't rub on road, but at full compression they'll still hit the spring perch. I would suggest either grinding the spring perch, RE weld on brackets if it's not a problem for you to weld, or RE bolt on brackets. The Tera and Currie brackets are great too, but I just like the RE's better after seeing them all up close. It's a new part so it's not advertised much, part # RE2005. |
#11 | |
#12 | |
The Nth brackets are really nice, but, they offer zero protection from your shock against the rocks. My shocks are trashed from running those brackets. If you look at the pic you can see how the eye of the shock is extending lower than the bracket, that's not good. |
#13 |
I've been struggling with the upper mount on my rear shocks all day now (loving the broken bolts). What options do I have? I'm not afraid to drop my gas tank again and have something welded in...
I've already got the RE mounts on the axle end. The setup for the top end mount just seems so hokey. Any suggestions appreciated! |
#14 |
It's Heep not Jeep
What ever happened to cutting the back half of the spring perch off? I have see alot of luck doing that method.
Jeep: 07 Wrangler X 2DR Black Crime Guard Alarm with 2way pager, AFE CAI, DynaPro Exhuast M.O.R.E. Body Lift, Source Co2 Tank, Stubbied Stock Front Bumper KMC XD 795 Hoss Black 17" wheels and Maxxis Bighorn 305/70/17 tires Every mod in the write up section. Old Jeep: 04 Wrangler X Yellow Built To The Hilt For Three Great Years. POLISH JEEP OWNERS CLUB #2 |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
