Currie steering issues - JeepForum.com
post #1 of 9 Old 05-07-2014, 09:39 PM Thread Starter
Shuggs
I just finished installing my Currie steering and overall I am very happy with it; however I installed it according to the instructions but still have a few issues with clearance during compression of my suspension.
The first is the the tie-rod clamp on the passenger side is preventing me from adjusting my toe properly, but I know i can solve this by swapping the bolt for a 2 1/4 long 3/8-24 bolt.
The second problem is that the tie-rod contacts the tip of the u-bolt that holds the stabilizer bracket to the drag-link. This occurs about 3" before the bumpstop cup contacts the coil perch. Can I just rotate the bracket up, or do I need to pull the axle back a little?
The third issue is the clamps on the drag-link adjuster look like they might contact something during compression. Unfortunately I can't verify this until I can solve the stabilizer bracket interference. If this ends up being a real issue I think it can be solved the same way as the first one, I just don't know what bolt size would work.
Any help would be appreciated since this is my DD so don't have the time to play around with it until I can figure it out.
Thanks
Shuggs is offline
post #2 of 9 Old 05-08-2014, 08:27 AM
DoughBro
I just did Currie steering too but I got my tie rod from Ironmand4x4 so I can't help with that....Could you slide the ubolts and bracket higher on the drag link? post a pic
DoughBro is offline
post #3 of 9 Old 05-08-2014, 08:43 AM
stump1
Originally Posted by Shuggs View Post
I just finished installing my Currie steering and overall I am NOT very happy with it;
Thanks
fickstit for u
MY RIG: http://i78.photobucket.com/albums/j87/ramburger/a0fcb769-5e55-4a62-8426-cb7cce41c0c2_zpsccea3c78.jpg
stump1 is offline
post #4 of 9 Old 05-08-2014, 11:56 AM
jeepinhokie
Thanks
1. whats wrong with the tie-rod clamp bolt? why is it preventing you from adjusting your toe? those clamps spin with the tie rod when you adjust your toe.
2. you can configure that steering stablizer bracket anyway you need to.
3. the drag link adjuster bolts shouldnt contact anything. mine contacted the tie rod after flipping my passenger side tie rod to the top using blains TRE flip insert. I was able to rotate the adjuster sleeve clamps to aleviate that problem though. keep in mind my tie rod and drag link are well used and are known to have slight bends in them.
HOKIES UNITED!
jeepinhokie is offline
post #5 of 9 Old 05-08-2014, 08:30 PM Thread Starter
Shuggs
Thanks for the reply.
There are small grooves in the tie-rod and drag-link adjuster that limit the clamp from rotating. I searched and found that replacing the ones on the tie-rod clamp with the 3/8 bolt will fix this, I couldn't find the size of bolt that will achieve the same thing with the drag-link adjuster.
Shuggs is offline
post #6 of 9 Old 05-08-2014, 08:32 PM Thread Starter
Shuggs
Originally Posted by stump1 View Post
fickstit for u
I am happy with it. While I may have some issues with it, I know they are fixable considering the number and variety of rigs that don't have those issues.
Shuggs is offline
post #7 of 9 Old 05-09-2014, 05:29 AM
Scott_98TJ
fickstit for u
He said it right, you didn't
I had to replace the bolt and spin the passenger side clamp on mine also, no worries on that. Stabilizer, as said, just make the needed adjustment, shouldn't be much. Not sure on your drag link, just to be sure, you are running a stock pitman arm right?
Hey jeepinhokie, Blaine's flip kit flips the driver side.... Unless you meant the sway bar bracket .... Still on first coffee in case I misunderstood lol.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer
Scott_98TJ is offline
post #8 of 9 Old 05-09-2014, 08:13 AM
jeepinhokie
Your correct. Drivers side, don't know what I was thinking.
HOKIES UNITED!
post #9 of 9 Old 05-09-2014, 08:49 AM
WeezyBlue
I rotated the clamp using a hammer as I spun the adjustor sleeve.
KD8UCX
05 TJ Rubicon DD
82 Wagoneer Limited WIP
06 TJ SE Sold
WeezyBlue is offline
