Currie Steering and dropped pitman arm question. - JeepForum.com
post #1 of 18 Old 07-22-2011, 07:59 PM Thread Starter
TanMan99
I scored a Currie Currectlync steering on craigslist for a steal knowing that one of the tie rod ends needs to be replaced. I did not notice at the time I bought it but I did notice when I got home that there is a slight bend at the driver side end of the tie rod. I'm not sure if it should be bent but I'm thinking a new tie rod along with the TRE.
I have some pictures of the bend in the tie rod along a straight edge for reference.
Another Question is the matter of my pitman arm. I think I've that the currie system works best with the OE pitman arm. I'm sure that my PA is dropped (installed by previous owner) and screwed up the steering geometry. Should I replace my PA with an OE PA and get my drag link parallel with the track bar?
Thanks!
TanMan99 is offline
post #2 of 18 Old 07-22-2011, 08:24 PM
mudb8
want it rite or rite now?
mudb8's Avatar
that's just plain bent!
it'll just make it hard to adjust the toe.
You need to remove the DPA and get a stock on put on there.......
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #3 of 18 Old 07-22-2011, 08:31 PM Thread Starter
TanMan99
Thank you! That is what I thought was the case. Anybody have an OE pitman arm laying around?
TanMan99 is offline
post #4 of 18 Old 07-22-2011, 08:32 PM
donnyb373
you can bend it out. I just had to do the sam ething with a way worse bend in the same spot and in the tie rod
donnyb373 is offline
post #5 of 18 Old 07-22-2011, 08:33 PM
greene69
I got a new one and it isn't bent at all. As for the pitman arm, mines stock and i have a 3" lift and 1.5" levling spacers and mine drives great.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #6 of 18 Old 07-22-2011, 08:35 PM
mudb8
mudb8's Avatar
OEM chrysler PN# 52038337, could be between 50-60 bucks, just call the dealer and give them the PN.
mudb8 is offline
post #7 of 18 Old 07-22-2011, 08:38 PM
mudb8
mudb8's Avatar
Flipped tie rod, high, dry and straight!
mudb8 is offline
post #8 of 18 Old 07-22-2011, 10:31 PM Thread Starter
TanMan99
I have seen those on Mrblaine's web site and have been put on the list along with the Anti-rock sway bar!
TanMan99 is offline
post #9 of 18 Old 07-22-2011, 11:28 PM
mudb8
mudb8's Avatar
on the list for what?
mudb8 is offline
post #10 of 18 Old 07-22-2011, 11:48 PM Thread Starter
TanMan99
my Jeep upgrades list!
TanMan99 is offline
post #11 of 18 Old 07-23-2011, 05:17 AM
Gary2
pitmans on Ebay for like 25 bucks
Gary2 is offline
post #12 of 18 Old 07-24-2011, 04:18 AM
-JD-
I need to replace the DPA that came on mine and a friend gave me his JK Stocker.
Anyone know if the JK and TJ/LJ stockers the same?
2006 Rubicon Unlimited 6-Sp Manual - 285/75/16 Cooper ST MAXX/stock Moab wheels, Savvy Under Armor BL/MML, Savvy Step-Rocker/Sliders, Savvy/Currie Ultimate Steering, Savvy UCAs, Currie LCAs, TBs and BSs, Nth/AEV 3" Springs, Rancho 9000XLs (255s/256s), ARB D44 Diff covers, Savvy/Tom Woods HD Rubicon Rear drive shaft, Genright Safari 31gal Tank Soon: Savvy LED Lights, new engine :-(
-JD- is offline
post #13 of 18 Old 07-24-2011, 06:07 AM
Gary2
don't know but I did put a YJ arm on my old 97 TJ
Gary2 is offline
post #14 of 18 Old 07-24-2011, 12:34 PM
mudb8
mudb8's Avatar
not all pitman arms are created equal......
mudb8 is offline
post #15 of 18 Old 07-24-2011, 01:07 PM
IEcrawlerTJ01
I noticed no body has talked about your tie rod yet
Since you need new tie rod and tre... Talk to Gerald at SAVVY and get there ultimate heat treated 4340 chromoly currie tie rod!
If you push it up against a rock hard enough it will bend and be genteler on other parts and it will bend right back after you get off the rock
The point is so that you can wheel hard and drive home with straight steering. Also if you have steering that is to strong like some people make it won't bend... But is so strong that it will take out other components and will bring up weak links else where
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
Currie HD Steering... Which pitman arm? DerekRI TJ Wrangler Technical Forum 10 03-13-2009 05:26 PM
Dropped Pitman Arm Question? USCGTWEET TJ Wrangler Technical Forum 5 01-30-2009 05:00 PM
dropped pitman arm? Gangreen4x4 TJ Wrangler Technical Forum 1 02-09-2006 06:43 PM
Question; Is a stock XJ pitman already dropped for a YJ lift? BombThreat YJ Wrangler Technical Forum 4 12-12-2005 07:36 AM
Dropped Pitman Arm mossimo19 TJ Wrangler Technical Forum 5 04-26-2002 11:27 AM
