currie springs vs. re springs - JeepForum.com
post #1 of 3 Old 08-05-2010, 08:34 AM Thread Starter
cmc1
I know a lot of people on this forum use savy products.and they sell the currie 4 inch springs.are they a better choice than the re 4.5s. such as ride quality(spring rates) and such? actual ride height isnt an issue as i have 5.5 re right now so im trying to lower the jeep a bit anyway. i have 35s so clearance isnt a big concern.thanks for any recommendations.
cmc1 is offline
post #2 of 3 Old 08-05-2010, 08:43 AM
Sundowner
I'm not really sure how the 4" springs would work with your 5.5" kit...that's an interesting bit of suspension geometry due to the 1.5" reduction in lift. I will say that mixing and matching between systems isn't forbidden by any means, but that I also cannot tell you how well it will work in this case.
In my experience, Currie makes a very good product across the board. I don't have experience with their springs, directly, but based on their other products that I've seen/used, I have no doubt that the springs are of very high quality.
Ride quality depends on a lot of things...vehicle weight and weight distribution, tires/tire pressure, shocks/shock mounting locations, etc, etc, etc...the Currie springs may change the ride quality, but I couldn't predict in what specific way.
Sundowner is offline
post #3 of 3 Old 08-05-2010, 09:18 AM
Dogman
Dogman's Avatar
From what I've read, the RE springs give about 1" more lift than stated. So, the 4.5" springs would actually give you about 5.5".
I thought the Currie springs ran true to size, but you would need to confirm that with someone like Gerald or Blaine that has more experience with those.
What shocks are you running?
John 3:17
Dogman is offline
currie , re , rubicon express , springs , coil , tj , wrangler
currie 4" springs or re 4.5s cmc1 TJ Wrangler Technical Forum 1 07-07-2009 06:51 PM
Clayton or Currie Coil Springs? Maverick906 TJ Wrangler Technical Forum 5 04-03-2009 04:41 PM
Currie Springs for a heavy LJ? UnlimitedNJ TJ Wrangler Technical Forum 5 10-16-2008 04:23 PM
Anyone running currie 4" springs? grnsporty TJ Wrangler Technical Forum 3 08-20-2008 06:30 PM
CURRIE springs bluYJ YJ Wrangler Technical Forum 3 06-20-2002 02:07 AM
