Currie HD Steering and my setup - Page 2 - JeepForum.com
post #16 of 36 Old 04-13-2009, 11:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
When checking that the track bar and drag link are parallel, don't be confused by the rods themselves. The track bar has some bends in it that can sometimes make it appear to be at a different angle than what it really is. What needs to be parallel would be the imaginary lines drawn directly between each of their two mounting points. If your upper track bar mounting point is stock and not dropped, and you don't have a dropped Pitman arm, I doubt they would not be parallel to each other.
Getting
Jerry Bransford is online now
post #17 of 36 Old 04-13-2009, 11:47 AM Thread Starter
dallasjetfan
2015 WK
They look to be parallel.
dallasjetfan is offline
post #18 of 36 Old 05-03-2009, 01:35 AM Thread Starter
dallasjetfan
2015 WK
Originally Posted by RubiconRazorbac View Post
Just for a safety check: With your possible bumpsteer along with the OME kit and JKS trackbar, check to make sure your trackbar isn't hitting that riddler cover when you hit a good dip or flex it out. This can be a problem.
Bumpsteer happens when your drag link and trackbar aren't parallel--like BarneyJEEP said, but there are several threads on this forum about trackbars hitting diff covers with your setup. That could be causing your problem as well.
Could the trackbar hitting the cover (albeit only slightly and infrequently) be causing the trackbar to come loose, shift, etc.? The problem seems to be getting a little worse and it started after I installed the Riddler covers. Coincidence?
post #19 of 36 Old 05-03-2009, 01:51 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't know what trackbar you have, but if you don't quit smacking it with the diff cover, you stand a strong change of breaking it at the mount and you won't like what happens after that.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #20 of 36 Old 05-03-2009, 02:14 AM Thread Starter
dallasjetfan
2015 WK
I have a JKS and Riddler cover. I sure wish Rokmen would have told me that they would hit.
post #21 of 36 Old 05-03-2009, 02:22 AM
mudb8
want it rite or rite now?
mudb8's Avatar
I don't have a drop pitman arm. Yes, my trackbar hits the Riddler cover, but only when I hit a speed bump too fast. And this problem has been here ever since the lift and new wheels and tires so i don't think the cover is the problem. I am about to check to see if they are parallel. If they are not, then how is this corrected?
http://www.jeepforum.com/forum/f9/tj-front-adjustable-track-bars-0-3-5-does-yours-hit-fit-738948/
drop pitman correctly used...
stock pitman correctly used...
improper dpa useage...
I think I caught a jks hint.... lol
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #22 of 36 Old 05-03-2009, 02:33 AM Thread Starter
dallasjetfan
2015 WK
So, should I get rid of the JKS TB or the Riddler? And could the hitting of the two caused the TB to come loose or something and would that give me some steering problems?
post #23 of 36 Old 05-03-2009, 02:42 AM
mudb8
mudb8's Avatar
I actually like the jks bar, it's not the strongest one out there, but on some apps. it'll hit the stock cover also...
check out this thread..
http://www.jeepforum.com/forum/showthread.php?t=738948
I also made a bracket which I believe will make it clear the riddler... don't have one to try it on...
mudb8 is offline
post #24 of 36 Old 05-03-2009, 02:51 AM Thread Starter
dallasjetfan
2015 WK
OK, so what should I do at this point? Rokmen said that it shouldn't be a problem. I didn't notice it hitting on the stock TB. I don't want it to break nor do I want it to mess up how my Jeep steers. It seems that since it started hitting that I am getting more and more steering issues especially on the highway. I'm sure it could be the tires or balancing issues, but I don't think so.
post #25 of 36 Old 05-03-2009, 08:22 AM
RubiconRazorbac
RubiconRazorbac's Avatar
I got the JKS to go with a 2.5" lift. The guy at Rough Country said theirs (RC) will definitely hit if you disco the sway bar. After sifting through threads, the odds are about 50/50 with the JKS. With 2.5" of lift PLUS an aftermarket diff cover, the chances of the TB hitting the cover are pretty high. So far, from what I've read, your best bet to prevent contact is bump-stops. Yes, that'll limit your uptravel, but if you're putting on bigger tires you'll want to keep them out of your fenders anyway.
Again, this is just what has been reported by other folks on this forum. Personally I'm extending the bumpstops just in case... Good luck!
Your shaft isn't long enough to handle that kind of droop...
My build thread:
RubiconRazorbac is offline
post #26 of 36 Old 05-03-2009, 10:54 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
JKS has made the Currie bars for years and now Currie has their own. You should check it out. They bumped the tube up to 1/4" wall Chrome moly, gusseted the JJ barrel at the frame, and bumped the bolt size up to 5/8" so you can use it where an RE was.
They added some more bend to clear the Rubi 44's and HP 60's. They also coped the tube differently so it's shifted to the front edge of the JJ barrel.
I am Savvy
mrblaine is offline
post #27 of 36 Old 05-03-2009, 12:53 PM
mudb8
mudb8's Avatar
now that's good info...
to bad jks doesn't make the track bars with the same .375 stock they use on the steering rods.
I'm attemting to shoehorn a superduty track bar in, mounted to the knuckle to go with high crossover steering, don't think I'll bend that one if I can make it work.
mudb8 is offline
post #28 of 36 Old 05-05-2009, 02:15 PM Thread Starter
dallasjetfan
2015 WK
OK, the trackbar is tight at both ends. I did notice that the draglink will rotate about 1/4" when twisting the steering stabilizer. Is that normal??
post #29 of 36 Old 05-05-2009, 05:24 PM
Jerry Bransford
Administrator
Yes, absolutely because it is attached via ball joints. If it were rigidly attached, it would break when the axle moved around.
Getting
post #30 of 36 Old 05-05-2009, 06:49 PM
rondak46
I could not solve the TB/Diff cover clearance problem so I went to 4" of lift. It worked.
rondak46 is offline
HP30 swap/Currie HD Steering/M.O.R.E. steering brace BigWaylon TJ Wrangler Technical Forum 32 01-02-2011 05:24 PM
Talk me into a Currie steering setup DAMRON TJ Wrangler Technical Forum 46 11-28-2009 07:44 PM
Shock Relocation setup - JKS v. Currie erickpl TJ Wrangler Technical Forum 36 07-13-2009 10:38 AM
Currie JJ control arm setup? Andre_ITALY TJ Wrangler Technical Forum 31 01-12-2009 09:46 AM
currie anti-rock setup miguelitojeep97 TJ Wrangler Technical Forum 24 04-07-2006 02:51 PM
