Quantcast Currie HD Steering and my setup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Currie HD Steering and my setup
Old 04-12-2009, 01:09 PM   #1
dallasjetfan
I have been reading about and researching the Currie HD Tie Rod and Draglink. I currently run the OME 2.5" with 1.25" JKS BL and 1" MML. I have adjustable trackbars and an OME Steering Stabilizer. I would like a little more control with my steering and I'm not sure if the Currie will help with this. How easy or hard is the installation. Also, does it replace the steering stabilizer or will I still need that?
dallasjetfan is offline   Reply With Quote
Old 04-12-2009, 01:15 PM   #2
bonesnv
The swap is straight OEM replacement and comes with mounting hardware to utilize your current steering stabilizer. Fairly straight forward installation as far as I know, just do an alignment when you're done and you should be good.
bonesnv is offline   Reply With Quote
Old 04-12-2009, 01:18 PM   #3
mudb8
want it rite or rite now?
mudb8's Avatar
currie is the best choice there. the size alone takes away the flex the stock units have in them.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 04-12-2009, 01:26 PM   #4
Jeepster83
the install is easy to say the least. the only special tool you need is a tie rod/pitman arm puller and you can rent one of those for cheap. my install took about 2.5 hours with regular hand tools and i did it by myself in my garage.
odds and ends youll need are new cotter pins and some grease and a grease gun. dont use an electric or other powered gun though. if it wont pump in by hand then drive on it like that for a little while and try again. dont force it though. there is very little room for grease in the ball joints so you wont need to use very much at all.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 04-12-2009, 01:35 PM   #5
crgrissom
Master of Reality
crgrissom's Avatar
My kit came with all the cotter pins needed, and I didn't need a tie-rod puller either. Just 'ring' the knuckles and pitman arm a few times with a BFH (leave the nut attached loosely so it doesn't fall) and they popped right out. Installing the new Currie stuff is easy, as he said.
Chuck
Chuck Grissom
Black Jeep Society Member
My Jeep
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline   Reply With Quote
Old 04-12-2009, 01:41 PM   #6
DBLJ
DBLJ's Avatar
If you cant get grease into one of them dont worry, they are made to not really need grease.
DBLJ is offline   Reply With Quote
Old 04-12-2009, 01:42 PM   #7
Jeepster83
Chuck
i guess i should have specified that i got mine used and needed to replace a few things.
Old 04-12-2009, 10:46 PM   #8
dallasjetfan
What kind of steering changes can I expect with the Currie? Anything that I should be able to feel?
Old 04-13-2009, 12:11 AM   #9
Jeepster83
it should feel exactly the same as a nice and tight OEM setup. its just a whole lot stronger.
what do you mean by you want a little more control? is it loose or you have a lot of play in the steering? does the Jeep lean way over when you turn? maybe a little more info would help out with your dilemma.
Old 04-13-2009, 01:05 AM   #10
dallasjetfan
Not sure if this is a dilemma, however, the steering feels tight. When I hit a bump while on the highway, I can get a decent pull in the steering. It probably has more to do with the MTZ's than anything. I was just wondering if this set-up would help with that type of stuff?
Old 04-13-2009, 05:55 AM   #11
BarneyJEEP
that sounds like bumpsteer
make sure your drag link and trac bar are parallel to each other.
are you using a drop pitman arm?
drop trac bar bracket?
http://www.kifourwheelers.com/
BarneyJEEP is offline   Reply With Quote
Old 04-13-2009, 07:51 AM   #12
BlackBellamy
Search for "bumpsteer" - that sounds like your issue.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline   Reply With Quote
Old 04-13-2009, 09:00 AM   #13
RubiconRazorbac
RubiconRazorbac's Avatar
Just for a safety check: With your possible bumpsteer along with the OME kit and JKS trackbar, check to make sure your trackbar isn't hitting that riddler cover when you hit a good dip or flex it out. This can be a problem.
Bumpsteer happens when your drag link and trackbar aren't parallel--like BarneyJEEP said, but there are several threads on this forum about trackbars hitting diff covers with your setup. That could be causing your problem as well.
Originally Posted by never monday View Post
when life gives you lemons.....make a trail rig out of it.
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/
RubiconRazorbac is offline   Reply With Quote
Old 04-13-2009, 09:36 AM   #14
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Your problem, as others said, sounds like bump steer. If a dropped Pitman arm has been installed, replace it with an OE Pitman arm which will cure the bump steer. Few TJs should ever have a dropped Pitman arm installed and those are only for specific situations.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 04-13-2009, 10:28 AM   #15
dallasjetfan
I don't have a drop pitman arm. Yes, my trackbar hits the Riddler cover, but only when I hit a speed bump too fast. And this problem has been here ever since the lift and new wheels and tires so i don't think the cover is the problem. I am about to check to see if they are parallel. If they are not, then how is this corrected?
Glock Forum
